E39 Pre facelift xenon headlight White Indicator
Abanko
Post by Abanko » Fri Jul 05, 2024 7:49 pm
Looking for a left headlight - xenon and white indicators. Replacing one that’s working ok apart from broken adjusters. Would consider switching to a pair of facelift if someone has some in good working order.
B10 V8 #842
BarryM
Re: E39 Pre facelift xenon headlight White Indicator
Post by BarryM » Sat Jul 06, 2024 9:52 am
It probably makes sense to replace the adjusters and do both headlights as if one has broken the other one won’t be far behind. It’s a bit fiddly but quite doable if you follow one of the YT videos (although 2003 units are sealed).
You also mention switching to facelift but xenon is a FC headlight!
Abanko
Post by Abanko » Sat Jul 06, 2024 2:10 pm
Thanks Barry
My car is a July 2000 build and has xenon’s with white indicators but no angel eyes.
Changing the adjuster could be way to go - did look at the videos but they looked very fiddly - will have another look
B10 V8 #842
BarryM
Post by BarryM » Sat Jul 06, 2024 4:18 pm
Apologies, tbh I wasn't aware the pre-facelift had a xenon option. Like many E39 owners I was a bit wary of replacing the adjusters but get the parts off eBay and make sure you have the right tools handy and just take your time :)
Abanko
Post by Abanko » Sat Jul 06, 2024 5:07 pm
Took an hour to work it out but came apart easily - just the electric adjuster at the bottom was tricky.
Waiting for the adjusters to arrive.
Thanks Barry for the advice!
B10 V8 #842
