How to identify part numbers?
nastypoker
Post by nastypoker » Tue May 14, 2024 10:16 am
I am a recent new owner of a 2016 D3 and looking to do maintenance myself.
I previously owned a BMW where I could plug the VIN into a decoder and get parts lists and diagrams but my Alpina VIN doesn't seem to work in the decoders.
I am currently looking for brake pads and discs all round but would like to know if there is a website with full exploded diagrams of this car anywhere?
DogWagen
Re: How to identify part numbers?
Post by DogWagen » Tue May 14, 2024 8:49 pm
Simple answer is there isn't. The Alpina Parts Manuals are downloadable from this website (look for downloads) and the rule of thumb is that if the part isn't listed in the Alpina Catalogue, then it's not been changed from the base vehicle (which is listed in the front of the catalogue) - use the BMW VIN and search realoem or other source for the part numbers.
Edit - just spotted that you've an F-series D3 - the parts catalogue isn't here but if you search the forum, you may find the question has been asked before.
Hope that helps,
nastypoker
Post by nastypoker » Wed May 15, 2024 1:24 pm
I couldn't find the part details on this forum or elsewhere online but I have managed to get the part numbers from a BMW dealer who said the front pads are on a 6-8 week lead time as they appear to be Alpina specific. £250 for a set of front brake pads is a bit steep!
Front pads B91.47.3.411.185
Rear pads B34.21.6.887.576
Front discs B34.10.6.797.606
Rear discs B34.20.6.894.382
I bet they are used somewhere else but with a different number. When I get them out, I will try and identify them further.
Meister
Post by Meister » Thu Oct 03, 2024 9:04 pm
Mate,
Have you identified an equivalent set of front pads to the B91.47.3.411.185 Alpina set?
The others which are all.BMW match my B4, fyi.
I've recently purchased a set of Febi-Bilstein discs for the car which are drilled, cut and rust proofed about the rims.
Fyi, the fronts are Febi-Bilstein 105720, product code PM1649421 a 370mm diameter disc which the BMW equivalent is 34.10.6.696.603. Plains are 34.10.6.797.606. The rears are Febi-Bilstein product code 8903124rmp, diameter 345mm and the BMW equivalent is 34.20.6.894.382 as you said. The discs are fitted to a.BMW 435d, f32 yrs 13/20.
Please update me as to an alternate set of front pads if you have found any? Looking at the calipher i am currently looking at M2 pads? Maybe the same? Sytner didn't know, they just quoted Alpina only at £250 + VAT!
Regards,
Carl
Alpina B4 Bi-Turbo F32, number 042 (current)
Alpina B3 3.3 Coupe E46, number 087 (current)
Triumph 1200SE Daytona (current)
Triumph Tiger 1215 XC (current)
Suzuki GT750A (current)
Suzuki GS1000E (current)
Yamaha RD350LC (current)
MV Augusta F4R (current)
churchie386
Post by churchie386 » Thu Oct 03, 2024 11:10 pm
The ALPINA pads for F3x B3/B4 are made by Pagid.
However, a common alternaive is to use F80 M3 pads; refer to this discussion .
Past & Present: Polo Match (Mk6); Alpina D3BT (F31); Alpina D3 S (G21); Forester XT (SG 2.0); 718 Cayman; Golf R (Mk7.1); 911 (997.2); 911 (996); WRX STI (Hatch); Alpina D3BT (E90); 330i (E91); Elise (S1); Fabia VRS (Mk1); 106 GTi; Octavia VRS (Mk2 estate); Impreza WRX (Wagon); Impreza Turbo (Wagon); Delta Integrale Evo; Golf VR6; 205 GTi 1.9; M3 (E30); 106 GTi; Clio 16v; 205 GTi 1.9; Escort Mk3; Escort Mk1
Meister
Post by Meister » Fri Oct 04, 2024 9:42 am
Churchie,
Thanks for the prompt reply and link to the information. Much appreciated.
Regards
Carl
