I dread to think what VPower is at the moment ...
...you'll need either an overdraft or a lottery win
I'd like it personally - the only thing the B5 suffers from is poor range. Appreciate it would be a bigger hit when you filled it up, but at least it would last longer.
Unless you're using large amounts in your garden tools the cost difference should be small - if you do use lots, and the mower isn't ancient, E10 should be fine if you add some fuel stabiliser, this will also prevent the fuel degrading if stored over the winterScooBeeFive wrote: ↑Wed Jun 22, 2022 9:21 pmI need to fill the mower fuel can up as well - that's going to be painful, as they recommend putting E5 Super in lawn mowers![]()
LOL, must be the way you drive Paul! I got 34mpg on M.way Saturday, average speed 72mph over 93 miles.
I've had the same recommendation - something to do with the E10 fuel destroying the carburettor diaphragm. It does mean that I can mow the lawn quickerScooBeeFive wrote: ↑Wed Jun 22, 2022 9:21 pmI need to fill the mower fuel can up as well - that's going to be painful, as they recommend putting E5 Super in lawn mowers![]()
The best I've ever seen was just over 30mpg on a run down to Folkestone last month. A lot was 50mph in the long sections of roadworks. On a normal motorway journey I'll probably see high 20s. Around town or having fun is usually in the teens. I think the G30/31 must be a bit better on fuel, unless I have a very uneconomical right foot!Grumpyjohn1957 wrote: ↑Wed Jun 22, 2022 11:04 pmLOL, must be the way you drive Paul! I got 34mpg on M.way Saturday, average speed 72mph over 93 miles.
Admittedly, it gets pretty grim in town traffic.
Couldn't bring myself to drive anything less though, what do you do?
It’s interesting the difference between cars.ScooBeeFive wrote: ↑Thu Jun 23, 2022 6:44 pmI think the G30/31 must be a bit better on fuel, unless I have a very uneconomical right foot!
