Has anyone here bought a used Alpina/Awron Datadisplay and been able to unlock it to use in a vehicle with another engine than the one it was installed in first?
I had one in my D3 F31 but it was stolen a while ago and I found a used that has been mounted in a F31 328i so I need to reset it so I can get all values for a diesel
Used Alpina/Awron display F3X
- $_57.jpg (628.02 KiB) Viewed 821 times
Re: Used Alpina/Awron display F3X
There certainly will be a way. Speak to ZED Coding
F31 335d
E39 M5
E46 M3
Clio 182 Trophy
E39 M5
E46 M3
Clio 182 Trophy
I had an Awron display in my F32 for a while, which was previously used on an M3, which worked fine.
My understanding is that later software updates from Awron unlocked the display to all cars. Since Awron now no longer exist, it was impossible to tell if it would work until I fitted it, which luckily it did.
I was in touch with Tom of European Auto Source who was extremely helpful and has extensive knowledge of Awron. You might want to try him if you need further assistance
tom@europeanautosource.com
Good luck
Pete
Good luck
Pete
2018 F32 B4s #275
2016 F32 D4 BT #160
2012 E92 D3 BT #248
2011 E92 D3 BT #209
2012 E90 D3 BT #372
2011 E90 D3 BT #403
2007 E90 D3 MT #594
1996 N Concours Ford Escort Cosworth
2018 F32 B4s #275
2016 F32 D4 BT #160
2012 E92 D3 BT #248
2011 E92 D3 BT #209
2012 E90 D3 BT #372
2011 E90 D3 BT #403
2007 E90 D3 MT #594
Thanks I'll try to contact him.PeterN wrote: ↑Tue May 10, 2022 12:30 pmI had an Awron display in my F32 for a while, which was previously used on an M3, which worked fine.
Good luck
Pete
Br.
Maciej
Don't get any reply from europeanautosource.com so is there anyone here that has a recent firmware file for the Awron display?
Hello,
I do have the same problem. I bought an Alpina Instrument out of an D3, and now in the B3 it is not working correctly.
I found out that there is a tool to reset the ECU ID. But neither Alpina nor Rob (current owner of Awron) have this tool. I also mailed Tom, and got an negativ answer from him.
My Investigations of the former Awron owners failed so far.
Is your instrument an original Alpina one or an Awron?
Perhaps we can swap them.
Kind Regards
Dirk
Kind Regards
Dirk
