MOT History is available - VRM was changed from private plate on 25 Sept so DVLA web service hasn't updated yet
18 June 2021
PASS 54,850 miles
8 November 2019
PASS 53,004 miles
1 August 2018
PASS 51,041 miles
26 July 2018
FAIL 51,039 miles
- Do not drive until repaired (dangerous defects):
-- Nearside Rear Tyre tread depth below requirements of 1.6mm (5.2.3 (e))
- Repair immediately (major defects):
-- Nearside Front Suspension arm pin or bush excessively worn (5.3.4 (a) (i))
-- Offside Front Suspension arm pin or bush excessively worn (5.3.4 (a) (i))
- Monitor and repair if necessary (advisories):
-- Offside Rear Tyre worn close to legal limit/worn on edge (5.2.3 (e))
3 August 2017
PASS 50,093 miles
5 August 2016
PASS 48,387 miles
7 August 2015
PASS 45,702 miles
4 August 2014
PASS 43,915 miles
- Advisory notice item(s)
-- Nearside Front Radius arm has slight play in a pin/bush (2.4.G.2)
-- Offside Front Radius arm has slight play in a pin/bush (2.4.G.2)
-- Offside Front Anti-roll bar has slight play in a pin/bush (2.4.G.2)
31 July 2014
FAIL 43,915 miles
- Reason(s) for failure
-- Offside Front Shock absorber has a serious fluid leak (2.7.3)
12 August 2013
PASS 41,169 miles
12 August 2013
FAIL 41,169 miles
-- Front Windscreen wiper does not clear the windscreen effectively (8.2.2)
10 August 2012
PASS 38,275 miles
Date tested
2 August 2011
PASS 35,581 miles
-- Front and rear tyres perishing due to age
-- Wiper blades smearing
5 August 2010
PASS 31,991 miles
8 August 2009
PASS 28,818 miles
30 July 2008
PASS 22,474 miles
23 July 2007
PASS 16,845 miles
