e46 rear arb drop link replacement top tips
rc944
Post by rc944 » Fri Apr 02, 2021 7:21 pm
ok so my advice is dont do it unless you have small hands, can get the rear wheels off the ground at the same time, have lots of patience, are happy to use bad language a lot.
while you're there, get the arb bushes changed and perhaps even the arb itself
you will need a good selection of size 13 wrenches including ring and open ended and decent 1/4" drive ratchet and 1/2" drive ratchet with a selection of deep and standard 13mm sockets and an extension bar
be careful not to overtighten the bolts that fix the arb mounting plate into the wishbone as its cast ally
needless to say i only intended to change the drop links but wish i had changed the other stuff. it was only when removing the other bits that i saw the condition they were in. the arb had some surface rust which i buzzed off. the arb bushes were fine in the end but for the sake of what they cost it would have been sensible to replace them for good measure. the arb itself is absolutely fine but im a pedant.
ill get them sorted when the car gets some serious preventative underbody stuff done at reddish later in the year
