Sourcing decent replacement wheel centres
Scotdoc
Post by Scotdoc » Thu May 14, 2020 8:43 pm
I have a D3 2010 coupe.
The wheel centre logos are starting to break down.
I previously bought some replacements for a BMW 3 series which lasted about 3 months - so wary of going cheap. Note originals are £££s!
Any suggestions for a supplier of reasonably priced non OEM parts which will last for a while?
cheers
jolls
Re: Sourcing decent replacement wheel centres
Post by jolls » Thu May 14, 2020 11:01 pm
A few people on the forum have used https://www.pukardesigns.com/product-pa ... eel-badges.
Collectingbrass
Post by Collectingbrass » Wed May 20, 2020 11:23 am
I used https://www.alloywheelsdirect.net/optio ... aps_alpina on recommendations from here. A single cap was £36 delivered including VAT, but delivery was a fixed fee if I remember correctly. I still need to fit the foam pads to stop the rattle.
2015 D4
2004 645Ci (sold regretfully)
2001 E39 525 (sold happily)
1997 E36 328 Cab (written off due to CAT theft :cry: )
2004 Z4 3.0s (I clearly have a habit...)
Norrie
Post by Norrie » Wed May 20, 2020 12:17 pm
I used Pukka, mine have been fine for 5 years.
F22 M235i - everyday driver
E 39 523i sold May 2023
Audi A6 2.5 Tdi had 2
Audi Coupe GT 1986 new
Mitsubishi Gallant & Sigma
Honda accord 2.2 coupe
bobbly
Post by bobbly » Thu May 21, 2020 9:36 am
Which wheels do you have? Classics, or dynamics. That's a good starting point. :D
Alloy wheels direct do the Dynamic centres at £22 each alpina pn 3613128, and the Classic centres at £23 ea alpina pn 3613135. That doesn't seem too expensive for the right part to my eyes, and is cheaper than direct from the sole UK concessionaire.
Bobbly
big blue
Post by big blue » Wed May 27, 2020 2:35 pm
Just a note on the originals iof sourcing from Sytner, they are around £120 each (metal cap, lock, key & access disc) so a set of 4 would be near £500 for an F30 generation.
Also one thing to factor in is that they dont come with the sticky pads. These need to be ordered separately and then added before application.
You would think that they all come as a complete set with centre cap and pads together but they do not.
Also if you have rattly ones, they can be remedied by replacing the sticky pads which is an easy task and not too costly.
2021 D3S G20 #014
2016 D3BT F30 #339
2013 D3BT F30 #028
2010 D3BT E90 #068
2007 D3MT E90 #289
Xiaorpowr
Post by Xiaorpowr » Mon Mar 22, 2021 5:55 pm
Hi mate, sorry to revive an old thread - new owner here.
Did you just stick these directly over the top of old centre logo? or do these pop right out?
Cheers,
F31 D3 Biturbo No.013
BMW E46 M3 6MT
Post by Charles » Mon Mar 22, 2021 6:41 pm
1. Remove centre cap
2. Dismantle badge carrier from centre cap
3. Heat badge gently with heat gun until it can be peeled off (make note of where on the badge "carrier" the P of ALPINA is located)
4. Clean surface of badge carrier to remove all adhesive residue
5. Apply new badge (making sure the P of ALPINA is in the correct place)
6, Reassemble badge carrier onto centre cap
Post by hap » Mon Mar 22, 2021 7:22 pm
:shock:
Xiaorpowr
Post by Xiaorpowr » Tue Mar 23, 2021 11:29 pm
Wow thanks for these detailed instructions... great pointer about the "P" location. I don't think I would have thought of that my self until it's too late.
If you don't mind, can I ask another question? I have one cap that looks like photo below and is very loose. I guess it was forced at some stage. I did a side by side comparison to another cap, can't see any visual differences. Have also tried this loose cap on other wheels and fitment remains the same (so definitely issue with this cap). Seen this before?
BMW E46 M3 6MT
Post by Charles » Wed Mar 24, 2021 10:50 am
Have you tried adjusting the L shaped lug on the back of the centre cap?
If you bend the tongue towards the back of the cap, this tightens the fit. It doesn't take much to pull it in
Xiaorpowr
Post by Xiaorpowr » Wed Mar 24, 2021 12:52 pm
I did but was worried i'd damage it, but I'll give it a bit more force.
Thanks for your help Charles.
BMW E46 M3 6MT
Post by Charles » Wed Mar 24, 2021 1:53 pm
They are designed to be adjusted - this is how ALPINA would achieve a good fit. The white pads are there just to stop paint on paint rubbing and not to adjust the fit, despite the numerous posts everywhere that discuss rattling centre caps and recommend extra padding.
My approach when tightening the fit was to lay the centre cap face down on a towel and apply a hammer gently on the end of the lug to move it closer to the rearside of the cap. Little and often, so keep checking the fit after each strike.
I now have individually fitted caps per wheel - with each cap identified for a particular wheel using a small piece of masking tape inside the cap and a permanent pen used to identify NSF, OSF, NSR & OSR
There is, however, a possibility that the cap in question has been forced and bent out of shape ...
Xiaorpowr
Post by Xiaorpowr » Sun Mar 28, 2021 10:43 pm
I had a bit of time on Saturday and did some hammering... worked a treat :twisted:
Thanks Charles! Great instructions.
BMW E46 M3 6MT
Post by Charles » Mon Mar 29, 2021 12:52 am
My pleasure :D
