Rebuilt engine oil usage
Post by Charles » Thu Apr 01, 2021 6:22 pm
I've managed 3500 miles in a year since the big rebuild and I've used 1/4 litre of oil.
Must be the new piston rings!
Yad3100
Re: Rebuilt engine oil usage
Post by Yad3100 » Thu Apr 01, 2021 7:07 pm
Charles, I don’t think this is bad, you will expect to use some oil bedding in, especially oiling of the bores.
The old YB in the Cosworth used to drink a half litre a month and this was even recognised in the owners manual.
Post by Charles » Thu Apr 01, 2021 7:16 pm
I should have been clearer - when the original engine was new, I used to burn through a litre of oil every 3000 miles which was perfectly acceptable and expected. Over time this worsened to a litre every 2000 miles and by the time I bit the bullet last year, was worse still at 1500 miles per litre. That said, ALPINA spec was that typical usage was a litre every 1000-1500 miles
This time round, I am on target for a litre every 14k miles - excellent job CPC :D
Post by simon13 » Sat Apr 03, 2021 10:16 pm
Charles have you stuck with the 0-30 grade piss they specced from new?!
Post by Charles » Sat Apr 03, 2021 11:23 pm
Nope - using Shell Helix Ultra 5W-40
Post by simon13 » Sat Apr 03, 2021 11:26 pm
interesting i've only ever used 5w40 silkolene pro S or titan racing now, and my engine has only ever done a steady litre every 4k on average since i rebuilt it about 55,000 miles ago
Post by Charles » Sun Apr 04, 2021 10:39 am
The first 180k miles were using 0W-30 and then, after rebuild #1, I changed to 5W- 40.
This time round, I chose to to stick with 5W-40.
