There goes another one!
Rambling from the Sage of Oxford
Jamie
Post by Jamie » Wed Aug 13, 2014 7:19 pm
Awesome, thanks for the updates...
Post by Charles » Wed Aug 13, 2014 8:18 pm
And there's more - just received a text to confirm that the head is back on and she should be running tomorrow :D
Clearly the HG turned up today!
Post by Charles » Fri Aug 22, 2014 11:34 am
Slight delay as one of the stud bolts was missing its thread on one end!!!
Anyway, car is back up and running and back at home :D
The new tappets have made a huge difference to extraneous noise, as has further work on the VANOS. Now you can hear the induction roar properly :twisted:
Pics to follow in due course as Mr Crouch is otherwise engaged at present.
Just need to work out why the aircon has stopped working ...
rc944
Post by rc944 » Fri Aug 22, 2014 3:05 pm
good news Charles...looking forward to the pics
did you end up replacing all the stud bolts in the end?
Porsche 997.1 GT3 CS I Alpina E46 B3s Coupe I Alpina E46 B3 3.3 Touring I Ducati 749S Mono I Ducati 748R I Ducati 749 Track Bike I Ducati 916S
Post by Charles » Fri Aug 22, 2014 4:33 pm
rc944 wrote:did you end up replacing all the stud bolts in the end?
We changed from a standard bolt set to an upgraded ARP stud system which has a separate bolt and nut.
ali
Post by ali » Mon Aug 25, 2014 8:48 pm
Was this new gasket the copper one that had been discussed before or something different?
Glad the old girl is on the go once more
B3 3.3 Coupe #090
D3 2.0 Biturbo Touring #098
Post by Charles » Mon Aug 25, 2014 11:28 pm
ali-bumble wrote:Was this new gasket the copper one that had been discussed before or something different?
Multi Layer Steel item from Cometic - with customised bore and thickness.
ali
Post by ali » Tue Aug 26, 2014 12:17 am
Is that like a plywood version of steel?
Does metal have a "grain" as such?
I know you can rearrange the molecules with varying heat treatments but not heard of this multi layered stuff.
Let's hope it does the trick anyway.
What was the verdict on piston number 1 , did it need replaced or new rings fitted? Any damage to the cylinder itself with the gasket debris flying around?
Sorry about the lots of questions but I do find this sort of failure and re=engineering rather interesting :roll:
B3 3.3 Coupe #090
Post by Charles » Tue Aug 26, 2014 7:30 am
Think of it as a sandwich with two bits of bread and a filling. In the case of an ALPINA gasket, the filling is organic (fibrous) whilst the MLS version has a steel filling which can be of varying thicknesses to give you the overall thickness you want.
Have a read here
No1 piston was "retired hurt" - pictures to follow in due course but, amazingly, no damage to valves, head or cylinder bore
ali
Post by ali » Thu Aug 28, 2014 11:34 pm
That makes some interesting reading.
I had no idea about the fibre sandwich!!
B3 3.3 Coupe #090
