e46 b3 3.3 touring coil spring sizes eibach
can anyone help me with part nos as realoem cannot. i need to replace all 4 coil springs with either some eibach or sachs units on a temporary basis
i can see 2 options here but not sure which ones are correct eg 228 or 238mm length
http://web2.carparts-cat.com/default.as ... 214&1273=6
would these work for the front ie 342mm
http://web2.carparts-cat.com/default.as ... f4b&1273=2
Re: e46 b3 3.3 touring coil spring sizes eibach
The ALPINA catalogues are here:
viewtopic.php?f=38&t=24985
thanks but i dont need the alpina part nos i have the part nos for alpina parts i am buying aftermarket for now so need to eibach or sachs part nos
ive asked Ed at cotswold hereford to shed light will report back
The springs are a 7-digit part number which means they’re a unique ALPINA part and as such you won’t find the exact spec/part available aftermarket
i know
i was surprised that realoem didnt have the part nos for a non alpina e46 330 touring hence my question
Think I've got all front and rear springs for a B3 3.3 sitting in my garage from when I renewed mine a couple of years ago. I'll have a look.
Sorry, hadn’t realised you were looking for aftermarket options. You’ll find that BMW used a couple of different spring specs dependant upon how many options the particular car had. RealOEM will just say refer to spring tables I’d expect.
That would be great thanks
from Ed
B31.33.1.093.068 front
B33.53.6.750.760 rear
Did u get this sorted in the end?
yep
May I ask the outcome?… I’m also searching for some replacement springs for my 2001 B3 touring.
