Wanted D5 F10 rear coil spring or part number
Desperate for something for your ALPINA.<br>
Ask here and hopefully someone can sort you out.
Shak146
Post by Shak146 » Wed Mar 12, 2025 9:23 pm
Hi guys,
I’m after a alpina D5 F10 rear coil spring or part number if any one can help. Local dealers are pointing me to alpina, who are then pointing me back to bmw dealers.
And not getting anywhere
Would it be a same set up as the 535d f10?
TIA
JCC
Re: Wanted D5 F10 rear coil spring or part number
Post by JCC » Wed Mar 12, 2025 11:31 pm
I’ve just bought an F11 D5 LCI and downloaded this document - here is the page with the rear springs - not sure why there are 3 options though. Hope this helps.
Shak146
Post by Shak146 » Thu Mar 13, 2025 12:51 pm
Thanks for reply, been struggling to get a part number the actual catalog refers you through alpina stock and not bmw.
Last attempt today if not f10 535d coils will be going in.
JCC
Post by JCC » Thu Mar 13, 2025 4:20 pm
I think the correct springs are Alpina specific as they are shorter than normal BMW ones - according to the original D5 press brochure.
Metrics
Post by Metrics » Sat Mar 22, 2025 6:10 pm
The D5 runs ALPINA specific springs made by Eibach. The different numbers reflect different versions based on spec of the car - the chassis number for your car will confirm which your car needs.
ALPINA springs will only be available via BMW dealers and quite likely take a few weeks to arrive. You can fit 535d springs, but they won’t be the same and it’ll affect how the car drives.
2010 E92 B3S Biturbo No.285
2012 F10 D5 Biturbo No.13
1993 Mercedes 190E 2.6 Sportline spec
1991 Mk1 Golf GTI Sportline cabriolet
Previous:
2019 G31 B5 Biturbo No.299
2002 E39 B10 V8 S No.60
