Brake discs and pads for a 2010 d3 biturbo
I'm having trouble getting front brake discs and pads for a 2010 d3 biturbo, any advice best firm which stocks these parts,,
Re: Brake discs and pads for a 2010 d3 biturbo
You shouldn’t have any trouble, it’s a standard 320d/325d set up. Problem is there are two different disc diameters, yours should be the 330x24 size discs (not the 312x24) part number 34116854999. Pads are again standard 320d/325d 34116799166 superseded by 34116771868 . Don’t forget the wear sensor too they commonly fail, again stock BMW but that one is a little harder to find the right one, they changed it in 03/2010, so could be one of two.
It’s usually the way you are asking; no one will have the D3 Biturbo brake parts, but everyone will have the E90 320d/225d parts….same thing.
Euro Car Parts or GSF Car Parts should have them, go for a quality make e.g. Pagid are OEM.
Have you seen the parts catalogue download on here for the D3 Biturbo, it’s all here:
https://thealpinaregister.com/forums/vi ... 38&t=24985
Then check the part numbers on realoem to see if they are superseded.
It’s one of the advantages of the E9X Alpinas, the ancillary parts are mainly from an uprated BMW bin and at present not expensive.
Thank you very much
No problem sir. Let us know how you get on.
For clarity, I think John means standard 325d/330d/330i discs and pads of diameter 330mm, thickness 24mm for the front of the E9x D3 Biturbo. Rears similarly are taken from E9x 325d/330d/330i models of the same build era. The standard E9x 320d brakes are smaller and won't fit the calipers. The details in the Alpina catalogues are correct, of course.
I used GSF car parts 'Drivetec' brand for a full disc and pad swap out last year, and they were faultless at a very reasonable cost.
HTH
HTH
Current:
23MY Porsche Macan GTS in Papaya
23MY Cupra Born V3 77kW in Aurora
Previously loved:
ALPINA: E91 B3SBiturbo #127, E92 B3SBiturbo #285, E90 D3Biturbo #097, E85 Roadster S #168 & variety of 'beige' 4 and 6-cyl BMW lumps.
PORSCHE: Macan S, Cayman 981 S, Cayman 981 GTS
Previously loved:
The 330x24 mm disc is found on later 320d’s too as standard, you just need to check the part number and size is correct:
- IMG_1047.jpeg (848.26 KiB) Viewed 315 times
