E92 D3 tyre pressures dynamic wheels
Does anyone have the correct pressures for the tyres?
My door tyre sticker is from a 6 series
Re: E92 D3 tyre pressures dynamic wheels
These are from the E92 B3 BiTurbo, the D3 is lighter at the front so may have slightly different pressures.
- 2E152B03-00F1-490E-ADA4-2BDA6667E834.jpeg (1015.42 KiB) Viewed 647 times
Thanks for that but ideally looking for D3 coupe sticker. Using 2.3 front and 2.4 rear at the moment.
Haven’t you got a supplementary handbook, that will have the correct values for a D3 BT Coupe.
The tyre pressures aren’t in the handbook it refers you to the driver’s door pillar.
It was the first place I checked myself and really surprised TBH.
I’ve all the pages photographed on jpg, everything else is there - tyre sizes, wheel sizes, how to use the inflator kit, take off the classic wheel caps, steering geometry for alignment, brake pads, oil and all capacities, but tyre pressures….nope.
They are in the BMW E92 main manual but these will be wrong.
That is really odd, like you say, I'd heard that most other things are detailed in there so I was assuming the pressures would be as well.
For ref - E90 Lci D3 BiT with std fit 245/35/19 front and 265/35/19 rear summer tyres on Dynamics - 2.2 bar front and 2.3 bar rear (32psi and 33psi respectively).
Door pillar label only mentions tyre sizes so pressures carry across classics and dynamics.
- Ninety Right
BMW Alpina E90 D3 BiTurbo
