🇳🇿 says hi, I've owned Milliy 4 days & 700 kms... what a machine!
Long-shot but does anyone have any further info/history on the B10 V8 cast block please? Such a special step you don't hear about too often, talk about an expensive way to increase performance.
Does BMW manufacture at the plant? and supply to Alpina to work their magic with new crankshaft, more aggressive camshafts, hand-fettled ports, lighter higher-compression Mahle pistons and reprogrammed the Motronic system.
Or does it come from a separate supplier to BMW?
Does anyone know if these blocks are only used in e39 B10's?
Look forward to any & all response.
Jon
B10 V8 Cast Block
B10 V8 Cast Block
- 0F2269C6-0A09-45F2-AB6A-87146C1F38BD.jpeg (2.62 MiB) Viewed 507 times
- F4ED4C50-C92B-4613-8328-8C9B4A292A91.jpeg (1.93 MiB) Viewed 507 times
- 70561B4E-DAE8-467D-B0B1-531CA9F05541.jpeg (2.46 MiB) Viewed 507 times
Re: B10 V8 Cast Block
The B10 V8 single vanos engine is also used in X5 4.6 IS
Alpina B10 V8 1999 4,6 347 HP http://www.bmw540.eu/Alpina_B10_V8.htm
BMW 540 E34 1994 4,0 286 HP - Sold
BMW 735 E32 1986 3,8 257 HP - Sold
BMW 745 E23 1981 3,2 turbo 252 HP - Sold
BMW 525 E28 1985 2,5 150 HP - Sold
