Finally got around to replacing the rear shock after getting a replacement pair sent to me from fmw following a warranty claim. only one was weeping but i sent both back and got 2 shiny new ones
rear shocks are v easy to replace but theres a few things to be mindful of
- piston nut is single use nyloc-style nut so just order new ones when getting your top mounts, washers, gaskets etc
- i replaced top mount nuts but they are not single use
- clean up the top mount fixing point in the wheel arch; it will be grubby and scabby potentially. good time to take stock of arch rust
- take a pic of the correct assembly before assembling the new strut - its easy to get stuff in the wrong order or wrong way around ie concave washer etc
- to minimise the rod rust issue i wiped them down with meths before applying a section of insulation tape where the threaded section begins as its here where the rust occurs as water is retained between the bump stop and rod; it may make the problem worse or it may help but i will monitor regularly
- there are 2 potential torque settings for the top mount nuts depending on the bolts used in the top mount
- torque up the piston nut before installing
- torque up top mount nuts in situ but needs a 1/4 drive ratchet capable of torquing to 30
- breaker bar to crack open the lower retaining bolt and the torque up to 100 on reassembly - no need to use new bolt
- youll have good access to springs and brake pipe section and union etc so have a good poke around
- i have a parts cleaner so cleaned the bump stop/dust boot and washers etc before reassembling, i coated the boot with wd40 inside and out and also within the stop to drive out moisture
remarkable how different the rear end feels with the new mounts. much more stable and planted.
good luck
e46 b3s coupe rear shock replacement top tips
Re: e46 b3s coupe rear shock replacement top tips
some pics
- IMG_20210306_1133286.jpg (2.36 MiB) Viewed 702 times
- IMG_20201031_1525301.jpg (2.23 MiB) Viewed 702 times
- IMG_20210306_1055086.jpg (1.26 MiB) Viewed 702 times
- IMG_20210306_1055043.jpg (1.69 MiB) Viewed 702 times
- IMG_20201031_1421174.jpg (2.87 MiB) Viewed 702 times
- IMG_20210306_1055124.jpg (1.3 MiB) Viewed 702 times
you can see the persuader in the top pic. the wheel was stuck to hub so it was encouraged off.
i buzzed the mating surface of the wheel and the disc rotor and a smear of the copper greaser on the flange that the wheel locates onto
Rogue engineering do a top mount that is bolted to the shell from underneath and therefore can be removed in entirety without removing the interior. It’s a good option for long term maintenance accessibility. I’ve used them twice, e36 track car and e30 touring, the latter is very difficult to access so only ever wanted to do it once.
Adam
Alpina XD3 #193
Alpina C2 2.7 #0525
E36 M3 Saloon
E30 track car M52
Alpina XD3 #193
Alpina C2 2.7 #0525
E36 M3 Saloon
E30 track car M52
Shocking attention to detail RC
Current
2004 BMW B3S #156 (Keeper)
2011, 2016, 2018 - Kia Sportage (Rolls Royce customer care)
2011 BMW Mini Cooper (Great fun, Solid)
2001 VW Golf GTI MK4 (Meh)
1994 Ford Escort 1.6 Zetec (light n dandy)
1991 Ford Orion 1.6 Ghia (beefy engine)
1984 Ford Fiesta 1.1L (Audio more expensive then car)
you know how it goes mate. catch up long overdue hope all good
