Cold Start Up Problem and Cog of Death - Alpina E46 B3.3 2002
E46330
Re: Cold Start Up Problem and Cog of Death - Alpina E46 B3.3 2002
Post by E46330 » Tue Apr 20, 2021 12:31 am
Charles wrote:
Sat Apr 17, 2021 4:16 pm
Might be worth doing a continuity check to make sure there isn't a poor connection or broken wire. Had this on mine recently.
I shall give them a heads up tomorrow and say this to them , even the best garages miss things so I wouldn’t be surprised if this is the problem. I’ve yet to hear back since Friday so if they don’t call me tomorrow , I’ll be ringing them. Really starting to miss the old girl now
(Current)
E46 Alpina B3 3.3 Saloon
(Previous)
E46 330i Individual Midnight Blue (write-off)
E46 330ci (sold) x 2
E46 330i (sold) x 4
E46330
Post by E46330 » Sun Apr 25, 2021 2:37 pm
I was hoping I wouldn’t need to update this thread any further , took the old girl out yesterday for a nice little drive and about 30 miles away from home both belts snapped ! Lost power steering and car started overheating. I turned it off immediately and got it recovered back to a garage. Won’t be able to have it sorted until Monday now , and nothing expensive , looks like all pulleys are intact and as is the engine fan. So hopefully no more surprises !
(Current)
(Previous)
E46 330i (sold) x 4
Post by Charles » Sun Apr 25, 2021 8:10 pm
How frustrating!
If funds allow, you might want to consider replacing the pulleys at the same time as the belts - as these wear over time as grit gets into the ball bearing runs.
ScooBeeFive
Post by ScooBeeFive » Sun Apr 25, 2021 9:40 pm
You're having a tough time of it with your new car. Don't give up on it - sure once it's sorted you'll have many trouble free miles.
E46330
Post by E46330 » Mon Apr 26, 2021 3:38 pm
Do you guys have any ideas what the part number for the alternator belt , power steering belt and alternator tensioner are ? As my garage can only source from BMW and it will take 2 weeks to arrive. Thanks in advance
(Current)
(Previous)
E46 330i (sold) x 4
E46330
Post by E46330 » Mon Apr 26, 2021 6:03 pm
How frustrating!
I shall be , I’m quoted £165 for the alternator tensioner from bmw , I think I’ll just order it and wait the time. Not much else I can do at this stage , hopefully this is the final hurdle
(Current)
(Previous)
E46 330i (sold) x 4
DogWagen
Post by DogWagen » Mon Apr 26, 2021 6:31 pm
Pending a reply from someone more knowledgeable.....When I did the belts on my B3s, I used realoem.com to work out the part numbers and cross-checked with the supplementary manual to make sure all matched; from memory, all standard BMW parts and none that were Alpina.
If you have the supplementary owners manual, the belts should be listed by type. If not, there's a B3 3.3 parts catalogue in the downloads section (it's in german)https://www.thealpinaregister.com/downl ... 20b333.pdf which I think has a belt listed. Failing that, the components should be the same as the engine type (S52 - a US E36 M3) that Alpina used as the base.
Hope that helps a bit.
E46330
Post by E46330 » Mon Apr 26, 2021 11:54 pm
That is brilliant ! Thank you very much , I managed to find just one belt on the German B3 parts catalogue the part number is 11281437929 on that list , for the B3 it only lists the one belt and I definitely took two separate belts off , alternator and power steering one.
It’s the tensioner that I’m wanting more so as £165 seems a lot especially when most tensioners are about £50. I’ll pay it if it’s the only option , but the waiting time is another issue about it.
The B3S catalogue lists two belts , so a little confused.
(Current)
(Previous)
E46 330i (sold) x 4
Bob
Post by Bob » Tue Apr 27, 2021 12:59 am
The way the catalogues work is that they only show the parts which deviate from the donor car or engine, so if a part isn't specifically listed you need to refer to the www.realoem.com using your BMW VIN or the source engine, S52 in your case. Any parts in the catalogue with a 7-digit number are ALPINA specific parts, the 11-digit numbers are BMW parts, just not from the donor car or engine.
E46330
Post by E46330 » Wed Apr 28, 2021 3:25 am
I caved and just decided to go BMW direct , it’s easier , less headache , and the wait time is the same regardless. It feels better staying true anyway , I did say from the beginning I wouldn’t skimp , especially on such small parts. I do hope this is me sorted for a while however as it’s getting a little constant at the moment. I do believe I’ve near enough changed everything that could go wrong at this mileage haha !
(Current)
(Previous)
E46 330i (sold) x 4
Post by Charles » Wed Apr 28, 2021 8:33 am
Let me check ...
E46330
Post by E46330 » Thu Apr 29, 2021 12:21 am
Let me check ...
Please don’t , I have nightmares thinking about it !
(Current)
(Previous)
E46 330i (sold) x 4
E46330
Post by E46330 » Thu Apr 29, 2021 12:23 am
Got the call today , parts arrived , so much for 2 weeks waiting time. Will be fitted on first thing tomorrow , coming in at £400 all in for 2 belts , alternator tensioner + fitting/labour. I’ve got a 1000+ mile drive planned for next month so I’ll be glad to have had this happen now rather than later ! Cheers for the help in this regard. I’m hoping this thread is done now haha
(Current)
(Previous)
E46 330i (sold) x 4
E46330
Post by E46330 » Tue Jun 15, 2021 5:16 pm
Now I am in need of a vacuum hose that connects to the intake hose which I recently had fitted , the garage cannot seem to source the part number so I thought I’d upload a few photos here and see if you guys might be able to point me in the right direction. The hose I need connects to intake bellow I’ve replaced and I have it secured on with a zip-tie at the moment. Apologies the pictures aren’t that clear but I’ve circled the top of the hose and I hope this is something to go on
(Current)
(Previous)
E46 330i (sold) x 4
