Thinking about upgrading and looked for performance comparison. Surely this cannot be correct - says the B3 is better? Any other comparisons or experience out there?
http://www.zeperfs.com/en/duel4673-6791.htm
B3 v’s B3s
Re: B3 v’s B3s
I don’t think you can expect a significant increase going from a B3 to a B3S but can’t believe it is actually slower. Also, the headline numbers aren’t the only thing, there should be subtle improvements in drivability/handling. You probably should try an S for a true comparison as you have a good appreciation of the B3’s abilities I presume.
Re: B3 v’s B3s
Yes, I’ve had the B3 for a couple of years and it’s been flawless - I like the adaptive suspension and xDrive on the G 31 so was looking to upgrade
Halscot
F31 B3
G31 540i xDrive
F31 B3
G31 540i xDrive
