- Moderator
Post
by Charles » Wed May 20, 2020 6:32 pm
MickB3 wrote: ↑Wed May 20, 2020 4:39 pm
Just to Update this thread.
The guys i used to strip and coat my wheels changed the valves without issue.
Amazing really, after all they had been in for 20 years.
Four new ones fitted and no leaks.
Pleased to hear it.
It isn't a difficult job but you just have to approach it with care and work on a "less is more" principle when unscrewing/screwing in the valve bodies
richb10touring
Post
by richb10touring » Sun Jun 14, 2020 10:18 pm
Useful thread - thanks to all contributors.
Does anyone have the size of the O-ring between the valve body and its seat in the wheel?
One of mine does this! And as I don't own a set of suitably long/slim/6-point sockets
yet I can't take it apart and look myself.
- IMG_0834.jpg (95.63 KiB) Viewed 2709 times
The wheels have been refurbed without stripping off the coat below, which is probably part of the problem, so I'm expecting some hassle in both removing the valve body and getting the seat in a suitable condition to make an effective seal.
2000 Alpina B10 3.3 Touring 26 - Sold 2008 and scrapped
2002 Alpina B3 3.3 Touring 113 - Sold 2011 and still going strong I believe
1999 Alpina B3 3.2 Convertible 77
richb10touring
Post
by richb10touring » Mon Jun 15, 2020 9:36 pm
I've just found a post from 2012 saying 8mm x 2mm, so will give them a go.
richb10touring
Post
by richb10touring » Tue Jun 16, 2020 9:32 pm
Future searchers may find this useful: Alpina's own mounting instructions for the internal tyre valves.
I have a 1/8 WW tap on order!
- 17343_3.JPG (66.9 KiB) Viewed 2692 times
Rav
Post
by Rav » Fri Jul 03, 2020 10:33 pm
Brilliant thread!
I am on the hunt for a set of Alpina wheel valves for my E46 B3 3.3. Can you point me in the right direction.
- Moderator
Post
by Charles » Sat Jul 04, 2020 10:05 am
Rav wrote: ↑Fri Jul 03, 2020 10:33 pm
Brilliant thread!
Charles wrote: ↑Sun Aug 05, 2018 2:16 pm
Part number is 91 47 3 610 061
A few quid from BMW ...
davettf2
- AL
Post
by davettf2 » Mon Jul 20, 2020 2:22 pm
Ah the delights of BSP threads. 1/8 BSP is considerably larger than 1/8 BSW Typically:
1/8 BSW OD: 0.125" Pitch 0.025" (40 TPI) Effective dia 0.109"
1/8 BSP OD:0.383" Pitch 0.035"(28 TPI) Effective dia 0.360" Designed for 1/8 schedule 40 pipe
If you have the valves measure the OD and pitch Hopefully if will align with the BSP
Dave
davettf2
- AL
Post
by davettf2 » Sat Aug 01, 2020 8:20 pm
Excellent, glad you have the correct helli-coil, There 'destructions' are partially correct as BSP has a whitworth thread form
Riobard
Post
by Riobard » Tue Dec 22, 2020 11:44 am
itsdashy wrote: ↑Sat Aug 01, 2020 12:25 pm
Tested on a scrap piece of ally and I can confirm that the instructions are talking a load of nonsense. It is 1/8 BSP
HI itsdasy, is there an acceptable metric alternative, perhaps M10? Made the same mistake and ordered a BSW 1/8, what a waste of time. Robert
davettf2
- AL
Post
by davettf2 » Tue Dec 22, 2020 10:25 pm
Hi, there really is not metric alternative in practice. The M10 thread OD is larger at 0.393 inch (theoretical peak), plus the pitch would be all wrong, M10 coarse (standard) is a 1.5mm pitch ( 16.9 TPI) even fine pitch M10 x 1.0 would be too coarse (25.4 TPI). In reality not worth the risk unless the matching valves are available.
Dave
Fast3000
Post
by Fast3000 » Wed Aug 25, 2021 11:54 am
Great thread. Noticed a dodgy inner core recently, it leaks when moved around or sometimes when I open the valve screw cap (Nice design with a rubber inside and seems to keep the air in! any ideas on part number? or Part number for 18 softlines on an e46.
Recent tyre place you will need to change the whole valve... Can I get away with changing just the core? And any recommendations on where to get these changed.
Current
2004 BMW B3S E46 Convertible #156 (Keeper)
2011, 2016, 2018 - Kia Sportages (Great brand service)
2011 BMW Mini Cooper (Great fun,)
2001 VW Golf GTI MK4 (Meh)
1994 Ford Escort 1.6 Zetec (Lght n dandy)
1991 Ford Orion 1.6 Ghia (Beefy engine)
1984 Ford Fiesta 1.1L (Big audio upgrade)
- Moderator
Post
by Charles » Wed Aug 25, 2021 12:10 pm
Fast3000 wrote: ↑Wed Aug 25, 2021 11:54 am
Great thread. Noticed a dodgy inner core recently, it leaks when moved around or sometimes when I open the valve screw cap ... Recent tyre place you will need to change the whole valve... Can I get away with changing just the core? And any recommendations on where to get these changed.
The core is exactly the same as any rubber valve - it screws in and out the same way but you need a clever little
tool. It sounds like yours might have just worked slightly loose within the valve body, so I would try tightening it up first.
If this doesn't fix it then any tyre place should be able to replace the core in a matter of seconds.
Fast3000
Post
by Fast3000 » Wed Aug 25, 2021 12:39 pm
Thanks Charles. Went to check again, on inspection and comparison to an ok valve. The valve pin moves around quite freely and that's because there is no bar across it where the clever tool would slot in to allow for tightening.
Current
- Moderator
Post
by Charles » Wed Aug 25, 2021 5:26 pm
Looked at mine - both on the wheels and the spares - and all the cores have a bar across them.
I would change the rogue one before worrying about whether the valve body is leaking air.
B7stuff
Post
by B7stuff » Tue Mar 15, 2022 6:40 am
Here's a stock photo from Alpina showing the valve and the hollow spoke.
- P1320166.jpg (34.94 KiB) Viewed 993 times
--- Alpina B5/B6/B7 supercharger parts and rebuild kits ----- www.b7stuff.com
