My D3MT drinks oil....
I_MNL
Location: Manchester, Cheshire and Hertfordshire! Driving on the motorways...
Post by I_MNL » Fri Nov 01, 2024 12:17 am
Hello peeps
As the title says...
And btw...been a while I haven't been here
So, yes, D3ALP drinks 1lt of oil every 800 miles
Turbo reconditioned
Intercooler changed
Water pump changed
And lots of other things changed
Oil changed to higher viscosity 10w40, 15w50
the only improvement is that now it drinks 1lt of oil every 800 miles. Before all these changes it was drinking 1lt of oil every 450 miles. Problem started about 10k miles ago
Ideas? Thank you!!
And the name is Marie-Noëlle or nick name MNL, NOT Marie or Noëlle ALONE; unless if you are looking for someone else and not me!!!
Car: D3 saloon 2007 and...a couple of cats made in 2003! and a little Scooby WRX STi...
jolls
Re: My D3MT drinks oil....
Post by jolls » Fri Nov 01, 2024 12:21 am
Have you checked the crankcase breather hose? If blocked I believe this can cause higher oil consumption.
B3 E46 no.265 gone but not forgotten.
I_MNL
Post by I_MNL » Fri Nov 01, 2024 12:22 am
Oh yes, thanks. I forgot...that was changed as well...twice...
I_MNL
Post by I_MNL » Sat Nov 09, 2024 10:15 am
No other ideas here please?
Wennar
Post by Wennar » Wed Nov 13, 2024 5:00 pm
I had a similar issue with my old diesel, and after changing the turbo, intercooler, and trying different oil viscosities like you did, it turned out to be worn piston rings. Mine was drinking oil at a crazy rate too, and the only real fix was a rebuild, unfortunately. I’d recommend doing a compression test just to confirm. It sucks, but at least you'll know for sure what you're dealing with.
I_MNL
Post by I_MNL » Thu Nov 14, 2024 10:55 am
Thank you for this
I was afraid it might be the case in the end... :cry:
Will have a check
