Backed out garage and noted oil on floor
Is this likely to be diff output seal ? Or leaking shock ? Will monitor and get it checked out by garage if more tomorrow
Ta
Small oil substance patch rear offside e46 B3s?
Re: Small oil substance patch rear offside e46 B3s?
you 100% sure the leak originated from that area? would be really surprising if there is a drip from the output seal or shock. they usually weep first and you would have seen signs before?
is it def oil and not brake fluid?
Well it was hard to see but I think u have a good shout at that I’ll put some card under it tonight see what Happens
This morning
- BB9DEE93-AFA1-4E4D-9864-10EA92D45CB9.jpeg (3.88 MiB) Viewed 470 times
- B2773F9C-CFE9-4B69-9B3D-7C125C6E78B4.jpeg (4.81 MiB) Viewed 470 times
get it on a ramp - wonder if its a failing seal/crush washer on diff drain plug or maybe input shaft seal. no biggie either way but best to get it inspected
