How to check if c2 2.7 alpina suspension is original
Hi guys, I was wondering if anyone would happen to know how one can tell whether c2 alpina still rides on its original suspension components ie springs and shocks? Are there any particular markings etc? Cheers Jazz.
Re: How to check if c2 2.7 alpina suspension is original
Yes there is.
The yellow bilstein shock absorbers will have Alpina stamped into them but its quite small, near to the bottom on the rears.
The springs will have alpina printed on them in white plus the part number if they are not too rusty.
E39 B10 V8/1 #81
E28 B9 3.5 #536
plus a few other BMW's.
Previously enjoyed
E46 B3 3.3 coupe #274
E60 B5 #329
E46 B3 3.3 Saloon #450
E92 B3 Biturbo #185
E46 B3 3.3 Saloon #114
E34 B10 Biturbo #445
E36 B3 3.0 switchtronic coupe #185
E46 B3S convertible #34
Many other BMW's
E28 B9 3.5 #536
Previously enjoyed
E60 B5 #329
E92 B3 Biturbo #185
Many other BMW's
Nice1, will check mine out.
With wear n tear over the years, what would ppl replace the original shocks n springs with? Is there direct replacement available ie without doing any modifications? Ta
Some pics of suspension components, do these look original to anyone knowledge?
- IMG-20200107-WA0007.jpg (165.46 KiB) Viewed 2594 times
- IMG-20200107-WA0008.jpg (207.38 KiB) Viewed 2594 times
- IMG-20200107-WA0005.jpg (185.71 KiB) Viewed 2594 times
- IMG-20200107-WA0006.jpg (293.52 KiB) Viewed 2594 times
Few more .....
- IMG-20200107-WA0003.jpg (140.91 KiB) Viewed 2593 times
- IMG-20200107-WA0004.jpg (190.3 KiB) Viewed 2593 times
- IMG-20200107-WA0001.jpg (144.55 KiB) Viewed 2593 times
- IMG-20200107-WA0002.jpg (166.8 KiB) Viewed 2593 times
- IMG-20200107-WA0000.jpg (144.55 KiB) Viewed 2593 times
They look pretty fresh and so I'd suggest they've been changed. Any markings or logos on the dampers & springs?
Looks like a clean and well cared for car, nice buy OP
E26 BCH is the reg if it's the one for sale last year
Clean the grime off the springs and look closely for alpina and part numbers printed in white.
The rear shocks will have ALPINA stamped into the near the bottom but its very small so impossible to tell from the pics you have posted.
P.S, dont put axle stands on the rear axle beam as it stresses the rubber beam bush. Place the axle stand under the beam bush pate if the stand is the correct shape.
E39 B10 V8/1 #81
E28 B9 3.5 #536
Previously enjoyed
E60 B5 #329
E92 B3 Biturbo #185
Many other BMW's
E28 B9 3.5 #536
Previously enjoyed
E60 B5 #329
E92 B3 Biturbo #185
Many other BMW's
They look pretty fresh as they car spent a lot of time in the south of France and has been off the road for some time plus is a low mileage car.
E39 B10 V8/1 #81
E28 B9 3.5 #536
Previously enjoyed
E60 B5 #329
E92 B3 Biturbo #185
Many other BMW's
E28 B9 3.5 #536
Previously enjoyed
E60 B5 #329
E92 B3 Biturbo #185
Many other BMW's
Hiya thanks for that, will do that. The pics with axle stands are from when previous owner had her.
I believe the owner of a newspaper group originally had this car on the Riviera.
What would be the correct and safest way of lifting the car from front and back? My mate got those spongey ramps, race ramps I think. Could someone advise where trolley jack should be located?
At the front the car should be lifted on the chassis rails and at the rear on the rear beam bush plate.
You can lift an E30 convertible on the sills at the jacking point with a rubber ramp pad so not to damage the sill lip but dont ever lift them with a trolley jack as it will damage the sill lip.
E39 B10 V8/1 #81
E28 B9 3.5 #536
Previously enjoyed
E60 B5 #329
E92 B3 Biturbo #185
Many other BMW's
E28 B9 3.5 #536
Previously enjoyed
E60 B5 #329
E92 B3 Biturbo #185
Many other BMW's
Cheers for that
