| View previous topic :: View next topic |
| Author |
Message |
Toby ALP
Posted: Sun Nov 25, 2007 5:40 pm Post subject: Creaking door seals |
| After a four year search search I've finally found a 2003 B10 3.3 touring. It's the family car of my dreams and is perfect in just about every way. However one thing that really bugs me is the creaking drivers and passenger door seals when driving around corners, over speed bumps, etc. I can't work out why this car does it when I never had this problem my old 528 that I owned for 4 years. The door seals all seem to be in good condition. It's really annoying. Has anyone else had this problem? Does anyone know how to fix it? |
| Back to top |
John B10 A
Joined: 06 Nov 2007 Posts: 65 Location: Angus, Scotland
Posted: Sun Nov 25, 2007 6:34 pm Post subject: |
I had the same noisy seal problem on an E39 530i and found that the BMW gooey stuff was only effective for a few weeks. I tried several things and eventually found that a Holts aerosol of Nylon and Rubber lubricant worked foe several months. Dont know if they still do it.
John. _________________ John Anderson |
| Back to top |
bern ALP
Joined: 24 May 2007 Posts: 273 Location: Wellingborough, Northants
Posted: Sun Nov 25, 2007 6:56 pm Post subject: |
Meguairs also do a nylon and rubber lubricant, but, i have only ever seen it at their premises, or, at shows they go to. never seen it in a shop _________________ Alpina B10 V8.(No 266)
E31 840ci Sport
E32 740i
E32 730
E39 520
Triumph 2.5 TC |
| Back to top |
Toby ALP
Posted: Tue Nov 27, 2007 11:23 am Post subject: |
| Thanks very much for the replies. It's a great relief to know it's not just my car that suffers this problem. I've also heard that vaseline can be used. BMW also apparently recognise the problem and have a product called Anti-Creak Agent (part number: 83 19 9 408 523) although it's quite pricey. Is this the "BMW gooey stuff" you tried John B10? |
| Back to top |
John B10 A
Posted: Tue Nov 27, 2007 4:33 pm Post subject: |
Hello. The gooey stuff was in a green tube and had a name beginning with "GUMMI------? I know that this seal noise was a problem with a lot of E39's so maybe they have had to develop something new. Must be worth a try.
| Back to top |
GrahamP ALPINA
Posted: Tue Nov 27, 2007 6:58 pm Post subject: |
If it's the same on the E46 as on the E39, it's the outer door seals that are the problem rather than the inner ones.
You could try removing any wax from the where the door seals contact the paintwork. Zymol HD-Cleanse would be good for this, or use a detergent.
Also try cleaning the flock covering on the door seals to remove any contaminants (i.e. wax, etc.).
Also make sure the flock covering on the door seals is in good condition and is doing its job of preventing any of the rubber from contacting the paintwork.
If all else fails, a last resort would be to fit new door seals one at a time and see if that works. _________________ Graham
B10 V8 #790 |
| Back to top |
Alpina Jim ALPIN
Joined: 12 Nov 2003 Posts: 745 Location: Near Portsmouth
Posted: Tue Nov 27, 2007 8:57 pm Post subject: |
Tinkerman,
I had a similar problem with my B10 until I used Gummifledge or however it is spelt, but I am not sure this is still available.
Not only do I apply it to all the rubber seals on the doors but also to the felt seal at the top and that was the end of the problem for me. I do this a couple of times a year and have had no creaking since. Basically I think it is a poor design issue with the E39.
If you do a search on the m5board.com site under the E39 M5 threads you will come across a variety of ways in which people have dealt with this problem.
Now how about my occasionally creaking sunroof? _________________ Jim
'98 B10 3.2 #174 in Alpina Blue owned since Sept 2002. |
| Back to top |
