Interior lighting issues
PostPosted: Thu Nov 08, 2018 12:55 am    Post subject: Interior lighting issues Reply with quote
As some of you may know, I recently had the dash out to replace the heater matrix.
However, since collecting the car, I have a strange issue with the interior courtesy lights. Prior to the dash coming out, whenever I switched off the ignition or unlocked the car, the front, central and rear courtesy lights would come on. Now, all I get is the front lights. Also, when I open the rear doors, the central lights do not come on, but opening the tailgate turns on the rear courtesy lights.
I am assuming that this is a coding issue which can be managed via an Autologic panel (or similar) but am not sure why the original settings have been “lost” when the dash came out.
Any thoughts?
PostPosted: Fri Nov 09, 2018 5:58 pm    Post subject: Reply with quote
Sometimes the simplest solutions are the best ones Exclamation
Having plugged the diagnostic control panel into the car this afternoon, only to find that there are no coding settings for different courtesy light arrangements, I decided to check the rear light fitting for any other reason. Whilst fiddling about trying to get the unit out of the headlining, the central bulb came on and everything was as it should be Shocked
Note to self: check electrical connections before jumping to conclusions Think
Page 1 of 1
