B6 2.8 /1 parts
Sechserreihe
PostPosted: Wed Sep 12, 2018 6:06 pm    Post subject: B6 2.8 /1 parts Reply with quote
Hi all,
New to the site and a new Alpina owner. Although familiar with BMWs, I've got a '72 2002 and a '78 635CSi Euro spec model, I finally landed an Alpina!
Car sat for a long time and has some rubber component issues under the hood. I'm in need of an intake boot that connects the Air Flow Meter to the intake manifold. This part has Alpina stamped on it and is therefore hard to find NOS or in good used condition.
Can anyone out there help out?
Also have some more diagnosing to do but I'm thinking my Alpina ECU that controls the injection is acting up. Car stops running (rough due to the air leaks from the bad rubber boot) after about 5-7 seconds. Timing light confirms that igniton spark cuts out at that time. I'm looking at Crankshaft position senor and other things but wanted to see if anyone has a good computer Alpina part number 1210118 SS2
Thanks,
Mark
View user's profile Send private message Visit poster's website
Ianb10fan
PostPosted: Wed Sep 12, 2018 6:58 pm    Post subject: Reply with quote
Hi , welcome to the register
Is this an e30 car ?, if so itís a very rare model and will have a m30 big 6 engine, Iím assuming you have tried alpina for the rubber boot , the chances of finding one are small Iíd think.
Maybe a 3.5 b6 will have the same hose or the original bmw 5 series can be modified to fit, hopefully someone with more knowledge can help you , good luck
Alpina b2.8
Alpina b10 3.2 no 64
Alpina b10 v8 no 147/1
Sechserreihe
PostPosted: Wed Sep 12, 2018 11:02 pm    Post subject: B6 2.8 /1 parts Reply with quote
Ah, yes, it's an '85 E30 B6 2.8/1. I've located a new one through KSK Distributing but at $238 I will check to see if one from an M30 BMW will work even with a slight mod if necessary.
Thanks,
Mark
Ianb10fan
PostPosted: Thu Sep 13, 2018 2:31 pm    Post subject: Reply with quote
Thatís good ,I had the Hartge version a few years ago , that made 210 bhp Iíd imagine the alpina will be similar if not a bit more , it was a lot of fun in a (dry)straight line !,lethal if wet
Alpina b2.8
Page 1 of 1
