Poxy washer tank - how many blasts before the light?
Post new topic   Reply to topic    theALPINAregister.com Forum Index -> ALPINA - Car Advice / Information
rc944
PostPosted: Tue Jul 10, 2018 1:44 pm    Post subject: Poxy washer tank - how many blasts before the light? Reply with quote
So i replaced both front and rear outlet grommets so i know the tank is water tight. i also dont see any signs of leakage from the headlight section
is it normal that i get fewer than 15 or so blasts of washer before the light pings up on the dash?
Alpina E46 B3s Coupe
E39 525i Sport Touring (again)
Ducati 748R
E39 525i Sport Touring (sold)
E46 330i Sport Touring (sold)
Porsche 964, 968 CS, 944 S2 (sold)
VW Mk4 R32 (sold)
CaesarBob
PostPosted: Tue Jul 10, 2018 2:43 pm    Post subject: Reply with quote
Seems like there is still something wrong to me.
Don't know for sure, but i've never come across a washer bottle that takes less than 2l of fluid.
So unless your "blasts" last for a good minute or so, I think you are still loosing fluid or the level sensor is fubar'd.
View user's profile Send private message AIM Address
Rav
PostPosted: Tue Jul 10, 2018 4:52 pm    Post subject: Reply with quote
My tank is 5.3 litres. Enough to fill a small swimming pool.
1999 #32 Alpina B3 3.3 saloon (UK Press Car)
2000 Porsche Boxster S
2007 Audi A6 Avant tdi
2002 Audi A4 Saloon tdi
rc944
PostPosted: Tue Jul 10, 2018 10:42 pm    Post subject: Reply with quote
so i know the sensor is fine which leaves one of two options
- there is still a leak somewhere
- or each blast is releasing a lot more fluid than it should
my e39 has a similar if not same sized tank and it lasts for ages. it doesnt have the fan jets like the e46 nor headlamp wash but i does have a rear wiper jet that i use often
Ducati 748R
VW Mk4 R32 (sold)
PostPosted: Wed Jul 11, 2018 12:53 am    Post subject: Reply with quote
you've got a leak still
rc944
PostPosted: Wed Jul 11, 2018 3:30 pm    Post subject: Reply with quote
aside from areas mentioned where else should i look?
Ducati 748R
VW Mk4 R32 (sold)
CaesarBob
PostPosted: Wed Jul 11, 2018 5:28 pm    Post subject: Reply with quote
If you're sure the tank is water tight, it must be in the pipework somewhere between the tank and jets.
Any sign of dampness on the ground under the car or under the bonnet? It may well be hard to tell but try operating the jets with someone watching (and trying not to get wet) to see if it leaks under pressure/use.
PostPosted: Thu Jul 12, 2018 9:16 pm    Post subject: Reply with quote
it has to be a leak from the tank area for the amount your losing. Fill it up and have a look?
Its only held on with 1 plastic screw? fill it and lift it up see anything obvious id say
rc944
PostPosted: Fri Jul 13, 2018 9:23 am    Post subject: Reply with quote
its very annoying. ive already removed it from the car and tested overnight to see if any leaks and none at all. had a feel of the feeder hose to headlamp washer and bone dry
im simply going to have to sell it
Ducati 748R
VW Mk4 R32 (sold)
Adwo
PostPosted: Fri Jul 13, 2018 10:22 am    Post subject: Reply with quote
Most common are the xenon washer pumps that extend when you use the washers..
Both sides use the same part number. (61678362823). Please look at the way the need to be mounted, I had to take the headlight of a second time because I screwed up the orientation.. Sad
Adwo
2009 E91 B3 Biturbo #40
2000 E46 B3 3.3 limo #172
1999 Mitsubishi Evo 6 RS
rc944
PostPosted: Fri Jul 13, 2018 3:42 pm    Post subject: Reply with quote
good intel thanks
how did you know yours needed to be replaced?
Ducati 748R
VW Mk4 R32 (sold)
PostPosted: Sat Jul 14, 2018 10:12 am    Post subject: Reply with quote
+1
Assuming you have checked the seals where the two pumps (windscreen and headlights) push down into the washer bottle, then the next likely culprit will be the telescope jets (mentioned by Adwo).
From experience, the connection between the hose and the jets fails after a while and it is worth replacing both the telescope and the connector on the hose at the same time.
Symptoms are a steady drip of washer fluid under the headlights which will fill the undertray. If slow then you may not notice it at first but if the problem has become terminal then it floods out Shocked
Teacher of Chemistry and driver of ALPINAs - not necessarily in that order Wink
Post new topic   Reply to topic    theALPINAregister.com Forum Index -> ALPINA - Car Advice / Information All times are GMT + 2 Hours
Page 1 of 1
