Scary shocks
rc944
PostPosted: Thu Jan 11, 2018 10:34 am    Post subject: Scary shocks Reply with quote
even though your dampers may not be leaking etc dont take for granted tehy are fine! pull the sleeves down and the bump stops and check the condition of the metal shaft/slider
ill post pics of mine later! think apple core...
mines 04 with 80k miles
Alpina E46 B3s Coupe
E39 525i Sport Touring (again)
Ducati 748R
E39 525i Sport Touring (sold)
E46 330i Sport Touring (sold)
Porsche 964, 968 CS, 944 S2 (sold)
VW Mk4 R32 (sold)
sat82
PostPosted: Fri Jan 12, 2018 12:01 pm    Post subject: Reply with quote
Hi rc944,
Are you referring to how rusty and chewed up the metal shaft is and thinning out?
If so, I to experienced the same on my rear shocks when I changed them back in June 2016 (mine had approx 105k miles). The metal shaft was rusted where water was getting in, due to the shock sleeve/protector had lost it's grip on the top of the shock and allowing water to get in and sit on top on the sleeve (retaining water) against the shaft.
As well as changing the shocks I had new shock sleeves and foam sponges installed. But a little tip to prevent the sleeve from slipping down off the shock (during wear and tear), wrap the top of the metal shaft with thick tape (to make the shaft thicker), then slide the sleeve on so it's nice and tight. This should help prevent the sleeve from sliding down and allowing water to get in and rust the shaft.
Doing my front shocks and springs next month (genuine Alpina parts), along with new shock sleeves, foam sponges, top mounts, top bolts, gaskets, lower spring rubber pad and drop links. Estimated cost with labour: 1500 ! ouch
Sat
B3 3.3 Saloon #540
Polo GTI
rc944
PostPosted: Sat Jan 13, 2018 11:42 pm    Post subject: Reply with quote
did you get a parts quote from fhw tuning as they supply the full kit for 1200 eur and thats including front and rear dampers and springs but not mounts
Ducati 748R
VW Mk4 R32 (sold)
sat82
PostPosted: Mon Jan 15, 2018 11:58 am    Post subject: Reply with quote
I didn't - I was unaware of that company. Also I thought that original Alpina parts could only be bought from BMW (or Alpina themselves)?
I will check them out - many thanks.
With regards to your original post, about the shock absorber shafts, was the condition of yours the same as I described for mine? With the rust issue and thinning down?
Sat
B3 3.3 Saloon #540
Polo GTI
jolls
PostPosted: Mon Jan 15, 2018 7:05 pm    Post subject: Reply with quote
For reference http://www.fmw-tuning.de/bmw/3er-e46/alpina-parts-1098/alpina-chassis-fe-bmw-3er-e46.html
rc944
PostPosted: Mon Jan 15, 2018 8:46 pm    Post subject: Reply with quote
yes!
Ducati 748R
VW Mk4 R32 (sold)
PostPosted: Mon Jan 15, 2018 10:51 pm    Post subject: Reply with quote
Bloody hell Shocked
2012 Alpina D5 BiTurbo No. 13
2002 Alpina B10 V8S No. 60
2005 Audi TT 225
1983 Mk1 Golf GTI
greenelekta
PostPosted: Mon Jan 15, 2018 11:00 pm    Post subject: Reply with quote
Shocking!
E34 M5 Touring Elekta British Racing Green
Z3 M Coupe Dakar Yellow
Z4 Monaco Blue
SLK55 AMG Silver
PostPosted: Tue Jan 16, 2018 12:57 am    Post subject: Reply with quote
mine were also like that when i changed them
sat82
PostPosted: Tue Jan 16, 2018 12:28 pm    Post subject: Reply with quote
jolls - Thanks for the link. Good prices on that site, compared to buying from BMW
rc944 - Yes, exactly the same as my rears
Sat
B3 3.3 Saloon #540
Polo GTI
rc944
PostPosted: Tue Jan 16, 2018 4:50 pm    Post subject: Reply with quote
for anyone cruising around in an e39/e46 or prior platform car, my advice would be to get yours checked no matter how pristine, low mile etc you think your car is!
Ducati 748R
VW Mk4 R32 (sold)
Page 1 of 1
