Tyre Pressure Monitoring - F30 series
- Hector's Dad
- Contact:
I've just put some winter wheels on (Alpina 19") which admittedly were sold as not having the pressure monitoring devices fitted, and I preformed the normal Reset procedure. The progress stayed at 0% which tends to confirm their absence. Unless there's a different procedure for linking the new wheels to the car?
Failing that, would the car also have the "old" system working on the ABS which whilst not giving me the pressures would inform me of a loss of pressure? If not, has anyone fitted a set of monitors? I know we used to manage without such technology but you get used to it!
D4 BT Coupé No. 166
D3 BT Coupé No. 127 (Sold at 147,000 miles)
I thought the pressure monitoring worked on a rolling radius basis and not from a set of pressure gauges mounted within each wheel - but it sounds like I am wrong.
If it is as you describe, then either you need to fit a set of gauges in the winter wheels or disable the system when on winters.
- Hector's Dad
- Contact:
I do actually get (with the summer tyres as supplied with the car) an on-screen display of the individual pressures which changes as the tyres get warm from driving so I'm assuming there must be a monitor in each wheel.
Of course I check my pressures manually so it's not an issue if it's not done by the car but it's reassuring to know that I'd get warning of loss of pressure - hopefully before it got so low that I'd notice it from the car's handling. These devices are reasonably expensive so I was hoping that the car would also have the system described by Charles.
D4 BT Coupé No. 166
A bit of digging suggests that the rotation method is no longer used by BMW because a runflat tyre will retain the same radius even if there is no air in it, so there is now a monitor in each wheel to provide a direct measure of pressure.
- Hector's Dad
- Contact:
The sensor has both pressure and temperature
Here’s a pic of mine from the Alpina Drive Day at Bilster Berg
Nothing to see here.... move along in an orderly fashion please!
E91 D3 Bi-turbo Touring #004 - (sold)
E46 B3 3.3 Saloon #032
F31 D3 Bi-turbo Touring #172
Mk1 Focus RS #516
Mk3 Focus RS Heritage #8 of only 50
and a 1987 Sierra RS Cosworth (currently being restored)
Mk1 Focus RS #516
- Hector's Dad
- Contact:
Re: Tyre Pressure Monitoring - F30 series
Do you have a link to the monitors you fitted?
Current:- F30 D3 BiTurbo (no.89)
Sorry, I don't. As I needed someone to remove then refit the tyres, I left it to my dealer (Dick Lovett, Hungerford) to source them. I think they contacted Alpina They weren't cheap!
F32 D4 BiTurbo
