B10 V8S advice on brakes and cooling
JASV8S
PostPosted: Sat Aug 12, 2017 4:14 pm    Post subject: B10 V8S advice on brakes and cooling Reply with quote
Hi Guys, Been out of commission for quite a while due to serious illness but now back and recovered enough to get the Alpina off SORN and back on the road but a few jobs needing attention and need some guidance.
1. Rear brakes are these standard 540 items? Looking at Eurocarparts Brembo discs and pads.
2. Front brakes, I have been involved in quite a few threads on this but have found this site and wondered if anyone has experience of them. Prices seem better than UK sourced. http://www.fmw-tuning.de/bmw/5er-e39/alpina-parts-1199/alpina-front-brake-discs-alpina-b10-v8s.html
3. Water pump is this also a standard 540 item and what is the recommended coolant brand/mix etc. Best source for a new pump.
4. I remember someone else recommended another small job being done at the same time as the water pump replacement but I can't remember what it was.
5. Headlight adjuster in driver's side wheel well is jammed solid. Appears easy enough to replace but are they easy to get?
6. Leaking hoses leading from power steering reservoir. Are these easy to replace or best left to Indy. Might be able to shorten them as a first try but not sure on success rate of that.
Once all this is done it will be ready for its Insp.2 and MOT.
Bronze F30 Xdrive
Silver E90 325iSE (sold)
Blue Mini Cooper (sold)
PostPosted: Sat Aug 12, 2017 5:18 pm    Post subject: Reply with quote
Hi John
Firstly, sorry to hear you've not ben well and wish you full health, nothing more important than our health.
My thoughts:
Standard 540 parts
Yes, the best option. Several forum members have bought from Frank and are happy.
Standard 540 part. BMW coolant.
No idea
Not sure what you mean? The adjusters are within the headlamp unit?
Worth trying the hose shortening method. I did on mine and while it improved it wasn't enough, so replaced the hoses and reservoir. Reasonably easy DIY, but I used a garage.
2012 Alpina D5 BiTurbo No. 13
2002 Alpina B10 V8S No. 60
1993 Mercedes 190E 2.6 Sportline
2005 Audi TT 225
1983 Mk1 Golf GTI
jamesa
PostPosted: Sat Aug 12, 2017 7:17 pm    Post subject: Reply with quote
Thermostat / Expansion Tank / Drive Belt / Timing Chain Tensioner ... ?
Are they actually leaking, mine used to `sweat`... with no loss of reservoir level
B10 V8 Touring #160 Alpina Blue ... SOLD
brett
PostPosted: Sat Aug 12, 2017 9:37 pm    Post subject: Reply with quote
Hi john
I bought pads and sensor from frank , superb service delivered in 8 days
sent me 2 sensors, so pm me and I will post you a spare
brett
E39 V8s (043)
JASV8S
PostPosted: Sun Aug 13, 2017 1:09 pm    Post subject: Reply with quote
Hi Metrics
Thanks for the kind words and I am recovering well. Thanks also for this info all good and I will probably take a similar path using a garage for some work as I need to get an inspection 2 done and also coolant and brake fluid changes so might as well roll these together.
I think the headlight adjuster I am referring to is possibly the levelling unit that attaches to the suspension in the wheel arch. Small black box with a lever attached. Mines appears to be seized.
Thanks again,
Bronze F30 Xdrive
JASV8S
PostPosted: Sun Aug 13, 2017 1:12 pm    Post subject: Reply with quote
Hi jamesa,
I am sure it was the tensioner I was thinking about but sensible advice on the other things.
Also i think my power steering might be more than sweating. Although I am not losing much fluid from the reservoir the under tray look pretty damp with fluid.
Bronze F30 Xdrive
JASV8S
PostPosted: Sun Aug 13, 2017 1:17 pm    Post subject: Reply with quote
Hi Brett
That's good news about Frank's site. I came across it a wee while back and thought it was too good to be true with the range of Alpina stuff especially V8S bits. Although I was thinking that the front brakes cost is probably more than all the discs and pads I have replaced added together and there have been quite a few. Anyway to buy an Alipna you have to be all in !!!
Bronze F30 Xdrive
164 coupe
PostPosted: Sun Sep 10, 2017 11:22 pm    Post subject: Reply with quote
Hi John
Glad to hear you're on the road to recovery and good to see you active on the forum again.
How's progress with getting the "S" back on the road?
Roy.
Roy Allan
D3 BT Coupe #164
Suzuki SV 650s
Black F56 Mini Cooper S 2.0 (Mrs 164's car)
Frozen Grey E92 M3 (Son's car)
Moonwalk Grey F56 Mini Cooper (Daughter's car)
Page 1 of 1
