B10 V8 Engine Noise - Help Required
ABRAD
Post by ABRAD » Wed Jul 12, 2017 1:04 am
Annoyingly Dellboys B10 V8 engine has developed an annoying tapping noise.
Still runs ok and about to get further investigation done - but would appreciate any information from owners of similar cars that may have had a similar issue??
The videos are pretty big showing it running so I've put them on the "Youtube" links below.
Any advice appreciated.
engine and tappet noise
https://youtu.be/s7Btd1JOQ8M
Exhaust Note Start Up and Tappet Noise
https://youtu.be/PA99hx50eUI
Engine Start Up and Revving
https://youtu.be/4peuRettFl4
Alex
Current Cars
Alpina B10 V8s (96/Avus Blue)
Alpina B5s (453/Sapphire Black)
Alpina D3 MT (348/Titanium Silver)
Volkswagen Golf GTI MK2 8V - looking sad for itself and to be renovated!!
Previous Cars
Renaultsport Clio 172
Volkswagen Scirocco
Vauxhall Cavalier SRI
Various Vectras, Laguna's, 406's etc - for work
v8 ego
Post by v8 ego » Wed Jul 12, 2017 9:35 am
I don't know definitively but I have seen a number of threads over the years about noisy VANOS units?
Regards,
James
2011 BMW 535d GT SE
2008 BMW 730d SE (SOLD)
2007 BMW X5 3.0d SE (SOLD)
2007 D3 Touring 166 (SOLD)
2005 BMW 750i Sport (SOLD)
2005 BMW 730d Sport (SOLD)
1999 BMW 750iL (SOLD)
1997 BMW 750iL (SOLD)
greenelekta
Post by greenelekta » Wed Jul 12, 2017 11:47 am
Sounds like it maybe a sticking hydraulic lifter/tappet. If the cars not been run for sometime the oil bleeds out the lifter, its check valve sticks not allowing the oil to pump it up. Hopefully a good run should sort it out.
E34 M5 Touring Elekta British Racing Green
E39 530i Sport Touring Sterling Grey
Z3 M Coupe Dakar Yellow
Z4 Monaco Blue
SLK55 AMG Silver
WINNE1
Post by WINNE1 » Wed Jul 12, 2017 8:35 pm
Hydraulic tappet for me. :!:
B6 convertible 4.4 black with silver decals .
B5 saloon 4.4 black with silver decals .
ABRAD
Post by ABRAD » Thu Jul 13, 2017 6:47 pm
Cheers Guys,
Hopefully it is that - but it has had a couple of short blasts on the mway - which quietens it but doesn't make it go away.
More investigation req. me'thinks!!
Doesn't seem to make any difference to it's running so I hope it's that simple as it was parked for ages.
Current Cars
Previous Cars
Volkswagen Scirocco
Post by Metrics » Fri Jul 14, 2017 9:47 pm
Really difficult to say as these noises are quite common M62 units of this vintage, but it could be anything from a tappet to vanos unit.
2012 Alpina D5 BiTurbo No. 13
2002 Alpina B10 V8S No. 60
2005 Audi TT 225
1983 Mk1 Golf GTI
Oneball
Post by Oneball » Sat Jul 15, 2017 9:30 am
There's a procedure for bleeding hydraulic tappets on an M62. Have a google and it should come up. It's something like hold at 3000rpm for 3 minutes and repeat 5 times. The BMW service bulletin does say driving won't work.
2004 B3S Cabrio
BarryM
Post by BarryM » Sat Jul 15, 2017 9:49 am
Hopefully it's just one of the tappets and it will disappear after a bit more driving.
My only caution would be to say that my engine had been carefully maintained for the last 5 years and was sounding great but after an innocuous short drive it had turned into a wreck as the timing chain guides gave up with no warning.
Not suggesting this is your problem but for peace of mind I suggest you find a mechanic who knows the M62 engine if the noise persists.
My guides are done now and the engine is back to sounding nice & quiet.
Enjoy the car 👍
Abanko
Re: B10 V8 Engine Noise - Help Required
Post by Abanko » Thu Jun 06, 2019 9:17 am
Well after 3 years and the noise getting a bit louder, I took the car to Phil at CPC. Turns out it’s coming from a cylinder valve due to some scoring. Luckily it appears to be one cylinder
As car is on 100k miles and has leaks from crank seal, timing chain cover and is also on original organic head gasket, timing chain guides not done yet, looks like it’s time to take the plunge and sort all the jobs in one hit and give the engine an overhaul.
While the engine is out, I expect there will be some other jobs that make sense doing - Phil seems to be the right man for the job.
Any advise greatly received.
Empty piggy bank time!
B10 V8 #842
E24man
Post by E24man » Thu Jun 06, 2019 2:15 pm
I know it's not much in the way of consolation but after nearly scrapping my B10 V8 Touring due to engine damage I bit the bullet, had it fixed and am now very happily using it as a my daily driver.
E24man
Abanko
Post by Abanko » Thu Jun 06, 2019 9:22 pm
Very true. In reality the cost is less than many pay a year in depreciation- well at least that’s what I have convinced myself off :D
B10 V8 #842
Abanko
Post by Abanko » Tue Jul 30, 2019 11:11 pm
Picked up the car today after 6 weeks of it being at CPC. After full engine strip down, lined and rebore of 1 cylinder, new piston, head gasket, and all seals replaced no more tapping noise!
Big thanks to Phil and Boris for doing such a great job!
Now need to get some gentle miles down.
B10 V8 #842
ABRAD
Post by ABRAD » Mon Aug 19, 2019 11:00 pm
Sorry to hear that it was such a big job, I thought that you had nailed it with the oil change at Sytners.
Did you also do the chain guides or were they ok.
Current Cars
Previous Cars
Volkswagen Scirocco
Abanko
Post by Abanko » Tue Aug 20, 2019 8:25 am
The oil change a couple of years seemed to get rid of the noise for a few weeks and then it came back. Phil at CPC had no real explanation on why the piston/cylinder had the issue but he has seen it a few times.
Yes timing chain guides were replaced and so were the con bearings. The main bearings were absolutely fine as were all the other pistons and rings.
So I am hoping that with the later x5 head gasket fitted and all gaskets/seals replaced, the engine is now not a concern for many years to come.
B10 V8 #842
Post by Charles » Tue Aug 20, 2019 11:01 pm
You couldn't have had a better person than Boris on the spanners. I was at CPC when he was mid rebuild. Glad all is now good 😀
