Hi all
just washed the car and noticed that the rear of the car is sitting at different heights?
The rear driver side is sitting lower than the rear passenger side, by around 3/4 of an inch, I filled up the tank 1 day ago but this wouldn't affect it would it?
Checked the tyre pressure and both rears are at 38psi.
Any ideas?
D3 MT ride height
- DonFlintoni
Hello
I have the same issue from time to tme. Because it is intermittent and dependant upon where I park I see it as a none issue. I think perhaps in your case a full fuel load an maybe a slight camber conspire to give you an uneven ride height.
Check to see if the front wheel which is diagonally opposite the rear with the biggest drop isn't in a rut. With the weight on the front wheels it might be pulling the rear end up.
Former Alpina owner. Having a break.
- DonFlintoni
