F30 D3
- AL
- Contact:
Re: F30 D3
Yep all the time . Damp cloth,,,make sure not grit .
Simon Rose Msc Bsc Hons MCOptom
Alpina F31 D3 Bi Turbo Touring #218, build 01/06/2016
Mediterranean Blue/Oyster Dakota Leather, black trim, Registered April 2018
Alpina E85 Roadster S #19 Silver /Black Leather/ Lux Registered 2004, Press launch Car.
Porsche 911 996 Targa Silver/Black leather, manual, registered 2002.
BMW f800r, Motorsport Red, white and blue, registered 2019.
Re: F30 D3
That’s good to know it’s not only my car so. I asked Bmw but they said we’re not sure as the it’s a rare car. It’s dirtier than my f30 330d was . Those exhaust pipes would stay spotless.
What colour is your car? Mine is white and I drove an 8 hour trip last weeekend. And the car was clean leaving and had some dirt on the tips and bumper . I heard it do an exhaust regeneration too . So that might have caused some of it ...
Re: F30 D3
Soot on the bumper doesn’t sound right, it might be worth having it checked over to be sure as you may have a fault with the DPF.
Re: F30 D3
You think the Dpf could be cracked ? I have seen many dpf,s off cars and some that were blocked and some that were cracked ! I just kind of thought that with these cars and the lack of mufflers or back box it allows a little more fumes to Escape hence the tips being dirty ...
Re: F30 D3
Maybe upload some images of the rear with the issue shown. Mine has nearly 60K on it and looks okay the pipe insides are clean as a general statement and the Akrapovic chrome does not get soot on it.
2021 D3S G20 #014
2016 D3BT F30 #339
2013 D3BT F30 #028
2010 D3BT E90 #068
2007 D3MT E90 #289
2016 D3BT F30 #339
2013 D3BT F30 #028
2010 D3BT E90 #068
2007 D3MT E90 #289
Re: F30 D3
Mine are usually clean. The inside of the pipes has a baked on layer on it, but that can be scraped off. The edges of the pipes are always spotless. the car has done 74k. My old 335d (with DPF) would smoke occasionally, but that was never a problem and it never had a DPF issue.
G21 D3S #356
Re: F30 D3
Sent the car in for my annual oil change , they did some tests on the dpf and all is ok. But the pressure sensor they said was behaving oddly changing pressures and readings etc so they have ordered a new one . Hopefully it’s all ok after
