vermetje
Post
by vermetje » Thu Feb 07, 2019 10:52 pm
Hello everyone,
I'm Joran, I'm 22 years old, and from Belgium. I'm new to this forum.
I'm the owner of a 1993 e36 convertible.
I have found an alpina e36 b3 engine to put in my car.
But I want to check if it's a real alpina engine, are there some numbers I can check?
I has the correct valve cover, and a the recommended sparkplug sticker says also alpina.
Hopefully you can help me.
Kind regards
AG
Post
by AG » Fri Feb 08, 2019 3:40 pm
you'd probably need the ECU or a suitable chip to run it properly to get the best from it. Is it a 3.0 or a 3.2 engine?
not sure on engine numbers though.
2000 e39 B10 V8 Touring
1985 e23 B10 (sold)
vermetje
Post
by vermetje » Mon Feb 11, 2019 10:23 pm
thanks,
the ecu is supplied with it.
Are there supposed to be alpina stickers on the ecu?
It's a 3.0
Thanks for your response
Post
by simon13 » Tue Feb 12, 2019 9:18 pm
Whats stamped on the engine block?
Also the cylinder head will have a 4 digit stamping on it at the back of the head
AG
Post
by AG » Wed Feb 13, 2019 10:46 am
mine (3.0) had the Alpina parts sticker on the outer case of the ecu and I'm sure it had the Alpina part number on the chip inside. However it's a slightly different story with the 3.2's.
1985 e23 B10 (sold)
Post
by simon13 » Wed Feb 13, 2019 9:42 pm
AG wrote:mine (3.0) had the Alpina parts sticker on the outer case of the ecu and I'm sure it had the Alpina part number on the chip inside. However it's a slightly different story with the 3.2's.
they all have that down to E30s
