D3 2.0 or 3.0
Post new topic   Reply to topic    theALPINAregister.com Forum Index -> ALPINA Buying Advice
floz61
PostPosted: Thu Oct 04, 2018 9:21 pm    Post subject: D3 2.0 or 3.0 Reply with quote
Hi All,
I have previously only owned Petrol version Alpinas, e30,e36 and e46 but would be interested in your thoughts on the 2 litre and 3 litre diesel cars.
Pros and cons and what to look out for would be much appreciated!
Regards,
Mark
DonFlintoni
PostPosted: Sat Oct 06, 2018 12:37 am    Post subject: Re: D3 2.0 or 3.0 Reply with quote
floz61 wrote:
Hi All,
Regards,
Mark
D3MT & BT common faults: Door lock actuators, blocked washer bottle, dual mass flywheel vibration, leaking fuel filler/overflow pipe.
MT specific faults:
Blocked DPF caused by failing glow plugs/glow plug relay
Acceleration flat spots and lag cause by big turbo
MT specific cons: custom garret turbo - expensive to fix/replace.
Eats rear tyres if driven hard.
Performs to ~95% capability on 'budget' tyres - michelins are best but they dont last as long and make driving challenging in the wet when beyond 50% worn.
MT positives: 45mpg+ on motorway driving. Plenty of oomph for overtaking. Great balance of chassis and suspension means it handles really well. Comfortable ride considering low profile tyres.
Good looking car inside and out - still turns heads at 12 years old.
D3 MT - 174 in Graphite Grey
floz61
PostPosted: Sat Oct 06, 2018 8:53 pm    Post subject: Reply with quote
Thank you for that, does anyone have any input for BT and the differences between 2 and 3 litre models. Rolling Eyes
ade and liz flint
PostPosted: Thu Oct 11, 2018 11:42 am    Post subject: Reply with quote
Depends what your target is. Faster, or nimbler.
E9x D3biturbo is best handling Alpina I've owned by a long chalk due to weight distribution. F3x D3biturbo is far quicker, but that has its limits of desirably imo and higher all round costs. I prefer the looks of the E9x which is why I went back to one, albeit petrol, but that's an individual subjective opinion. E9x lci is super reliable and a better built base car than the pre LCI MT, and doesn't have the M47 reliability concerns and service costs. Just watch cars with high (>120k) mike's as cam chains can be an issue on poorly maintained cars with incorrect oil grades.
E91 B3SBiturbo #127
981 Porsche Cayman GTS
Focus STline dog wagon
floz61
PostPosted: Sat Oct 13, 2018 9:41 am    Post subject: Reply with quote
Thank you ! Very Happy
DogWagen
PostPosted: Sat Oct 13, 2018 4:14 pm    Post subject: Reply with quote
Not sure if this helps or hinders. I have had 2 E91s - both 3 litre diesel, standard BMW. One was a 325d and the other is my 335d daily. The engine is a jewel and the car is smooth, lots of torque, sweetly handling and surprisingly frugal. Both achieved >43mpg on the daily commute even with >120K miles Issues to watch for are:
intercooler pipe seals (they do go with age) but are an easy but filthy fix due to the fact that oil tends to seep out.
The intercooler exit pipe (aluminium, cold side) can be chafed through by a poorly positioned coolant pipe. I have repaired by welding to save the 300 replacement cost Ought to post up the how-to....
Thermostats (x2) tend to stick open with age - you need to check running temperature is >85C either with a diagnostic box or the hidden menu. Simple to change (EGR thermostat is a 15 min job)
Vacuum pipes and Crankcase ventilation valves fail with age - again simple DIY change.
At higher mileages, the lower suspension arms wear at the ball joints and the bushes - simple to replace with Lemforder parts and not expensive.
Summary - great to drive and will be better in the Alpina versions....but I still prefer my E46 B3s!!
Post new topic   Reply to topic    theALPINAregister.com Forum Index -> ALPINA Buying Advice All times are GMT + 2 Hours
Page 1 of 1
