update: the bottom of the block has been reassembled.
ali
Post by ali » Mon Oct 09, 2017 12:38 am
That is a serious amount of effort gone into your project
You say almost there, what is still left to do?
Sab
Post by Sab » Wed Oct 11, 2017 6:36 pm
ali-bumble wrote:That is a serious amount of effort gone into your project
Mainly exterior bits to do now.
Trims etc...
E36 B3 3.0 #178
E46 B3 3.3 #188
Cupra Ateca
E30 C2.7 - Stolen
If you ever have everything under control, you’re not moving fast enough
Sab
A Pillar trim
Post by Sab » Fri Nov 24, 2017 6:15 pm
BMW still had a few in germany.
I’m well chuffed with these as the current trim is looking a little tired after 22yrs.
E36 B3 3.0 #178
E46 B3 3.3 #188
Cupra Ateca
E30 C2.7 - Stolen
Sab
some Interior TLC
Post by Sab » Sun Dec 24, 2017 5:26 pm
Replaced the headlight switch.
Turn controls for heaters, fan and temperature.
And finally was able to source a glovebox torch.
[/img]Image
Image[/img]
E36 B3 3.0 #178
E46 B3 3.3 #188
Cupra Ateca
E30 C2.7 - Stolen
MCB
Post by MCB » Sun Dec 24, 2017 5:35 pm
Very nice indeed. I have about six of those glovbox torches kicking around. Not sure what state the batteries are in though. I have seen a working one fetch £40 on eBay 😲
1997 E36 Alpina B3 3.2 Touring. No.66
1998 E36 1.8 Touring
1989 E30 M3.
2004 E60 530D
2004 Vauxhall Signum (for the shopping)
2002 E39 M5 (Sold)
Sab
Post by Sab » Sun Dec 24, 2017 5:39 pm
MCB wrote:Very nice indeed. I have about six of those glovbox torches kicking around. Not sure what state the batteries are in though. I have seen a working one fetch £40 on eBay 😲
Cheers Pal.
It’s Christmas Eve and the weather is strangely mild, so I got her out one last time and decided I’ll takle some of the DIY bits.
E36 B3 3.0 #178
E46 B3 3.3 #188
Cupra Ateca
E30 C2.7 - Stolen
Sab
Post by Sab » Fri Apr 06, 2018 3:02 pm
Latest lot of parts on order:
F/R Suspension
• 91473131149 - F/R Shock.
• 91473131148 - F/L Shock.
• 91473133110 – F Coil X2 required
• 91473352114 – R Shock X2 Required
• 91473353107 – R Coils X2 Required
FRONT AXLE SUPPORT/WISHBONE
• 31129059288 – Rubber mounting X2 required
• 31126758510 – Wheel suspension joint X2 required
• 31111114348 – Washer X2 required
• 32216769539. Self locking nut X2 required
• 31106774717. Self locking nut X2 required
• 31111137888. Hex Bolt X4 required
Stabilizer, front
• 31351091764 – Stabilizer Link X2 required
• 31351127263 – Swing support bracket X2 Required
• 07129964672 – Self locking nut X8 required
• 07129922716 – Self Locking nut X2 required
• 31351090268 – Rubber mounting X2 required
• 31351131622. Stabilizer support X2 required
• 07119905515. Hex Nut X4 required
• 07119902955. Hex Bolt X2 required
REAR AXLE CARRIER
• 33319059300. Set rubber mounting
• 33319059301. Set rubber mounting
• 33171134871. Rubber mounting
• 33316770851. Vibration absorber
• 33321091100. Collar Screw
• 26111226237. Washer
• 33176760337. Hex bolt with washer
• 33331132546. Stopper X4 required
• 33311133463. Collar Nut X2 required
• 33311136428. Threaded bolt X2 required
• 33326760361. Reduced Shaft bolt
3' E36 325i REAR AXLE SUPPORT/WHEEL SUSPENSION
• 33321090693. Hex bolt with washer X2 required
• 33171090824. Hex bolt with washer X2 required
• 33321092247. Rubber mounting X2 required
• 33306852895. Ball Joint X2 required
• 33326771828. Rubber mounting X2 required
• 33326770824. Rubber mounting X2 required
• 33326863853. Eccentric Bolt X2 required.
• 33326760363. Eccentric flat washer X2 required
• 3332670668. Self locking collar nut X8 required
• 33321139132. Collar screw X2 required
Stabilizer, rear
• 33551131155. Rubber Mounting X2 Required
• 33506779734. Stabilizer support X2 required
• 07119905374. Self locking collar nut X2 required
• 07129922716. Self locking nut X2 required
• 07119913612. Hex bolt X2 required
• 33551126932. Stabilizer Link X2 required
• 07119902955. Hex bolt X2 required
• 33551139393. Swing Support bracket X2 required
E36 B3 3.0 #178
E46 B3 3.3 #188
Cupra Ateca
E30 C2.7 - Stolen
Sab
Cataloging parts
Post by Sab » Fri Apr 20, 2018 5:39 pm
Ok, so the above was ordered with various other bits like pads, sensors, etc...can’t list every item from a 8/10 page invoice
Or this may well turn out to be a long evening!
So I unpacked all the parts I’ve accumulated except the external mouldings (in storage).
Take a look at this lot!
[/img]Image
Image[/img]
E36 B3 3.0 #178
E46 B3 3.3 #188
Cupra Ateca
E30 C2.7 - Stolen
nealpina
Post by nealpina » Sat Apr 21, 2018 11:01 pm
Wow a brand new car there Sab
Well done :D
Oscar Wilde & Burkard Bovensiepen: I have the simplest tastes. I am always satisfied with the best.
ALPINA B3 3.2 Coupe Switch-Tronic ALPINA Blue
ALPINA B10 3.3 Saloon Manual Mora Metallic
Sab
Post by Sab » Thu May 03, 2018 6:43 pm
Had the o rings on the a/c compressor and hoses done today as there was a minor leak.
The brake calipers are almost ready.
Collected this lot also.
[/img]Image
Image[/img]
BTW - meet my assistant Buddy.
E36 B3 3.0 #178
E46 B3 3.3 #188
Cupra Ateca
E30 C2.7 - Stolen
Sab
Post by Sab » Wed May 09, 2018 3:33 pm
Being prepared to go to the Bodyshop.
[/img]Image
E36 B3 3.0 #178
E46 B3 3.3 #188
Cupra Ateca
E30 C2.7 - Stolen
Sab
Post by Sab » Thu May 10, 2018 5:30 pm
Image[/img]
E36 B3 3.0 #178
E46 B3 3.3 #188
Cupra Ateca
E30 C2.7 - Stolen
Sab
Post by Sab » Fri May 11, 2018 1:12 pm
PPF for Headlights and Fogs.
Arrived today from the US.
Image[/img]
E36 B3 3.0 #178
E46 B3 3.3 #188
Cupra Ateca
E30 C2.7 - Stolen
rc944
Post by rc944 » Fri May 11, 2018 4:04 pm
who did your callipers?
Sab
Post by Sab » Fri May 11, 2018 5:19 pm
rc944 wrote:who did your callipers?
They also arrived today and look great!
Biggred did the calipers -
Speak to James Priest - http://biggred.co.uk
[/img]Image
Image[/img]
To complement these, I’ve ordered 4 protection plates, new pads, sensors, retaining clips, carrier bolts and new brake hoses.
E36 B3 3.0 #178
E46 B3 3.3 #188
Cupra Ateca
E30 C2.7 - Stolen
