Dust and bugs
Alpina Jim
Dust and bugs
Post by Alpina Jim » Thu Jun 22, 2017 3:30 pm
My B10 only gets used occasionally, and hence washed infrequently, but it tends to pick up an annoying coat of dust while sitting in the garage. I guess it is a case of using a car cover or similar but I like to see the car when I go out to the garage for whatever reason. So the question is whether there is an easy way of removing the dust apart from having to rinse it off? Does an Arizona duster actually work without swirling or scratching the paint? Any tips please?
Also, bugs. After a 50 mile round trip recently the front of my B10 is nicely bug splattered but otherwise the car does not need washing. Can anyone recommend a bug removing spray that works well without marking the paint or taking off the carnauba wax finish?
Thanks in advance.
Jim
Bri-E
Post by Bri-E » Thu Jun 22, 2017 6:11 pm
An AirFlow car cocoon, or similar, will let you see the car when you go to the garagae or cheaper a cover is the way to go for the dust issue.
Simoniz Bug Shifter is a brilliant also AutoExpress Products Award winner 2014. Spray on leave a bit, rinse off and dry no need to wash whole car.
Bri-E
D3BT Touring (2014) #015
D3BT Touring Swithtronic (2012) #402 Sold
D3 (2007) #538 (Sold but remembered)
120d Sport (2004)
318ti SE Compact (2001)
318tiSport Compact (1998)
318ti Compact + Sport pack (1995)
Ford Capri 2.0 Laser (1985) 200,000 miles passed
PhillV8S
Post by PhillV8S » Thu Jun 22, 2017 7:12 pm
I have a carcoon for mine as I got fed up with all the crap on car after putting it away for a week!
E39 B10 V8S #037 Saloon SOLD
Range Rover TDV8
Subaru Outback 3.0
E64 B6s Cabriolet #100
Alpina Jim
Post by Alpina Jim » Thu Jun 22, 2017 8:29 pm
Thanks for the replies gents.
Unfortunately my garage although plenty long enough has limited width and I do not think a Carcoon or similar will fit very well. I need access to walk through the garage as there are stairs at the other end to get to my workshop above.
The Simoniz bug shifter sounds excellent so I will get some and give it a go.
Jim
PhillV8S
Post by PhillV8S » Thu Jun 22, 2017 9:00 pm
Don't write off the idea, I've seen these and other similar alternatives put into some tight spaces. Thee sides have access doors to allow access/egress. Check what space you have and check the size of car shelters, as long as it's about 12inches on width and length then you will probably be ok to fit one.
Range Rover TDV8
Subaru Outback 3.0
Arvi
Post by Arvi » Fri Jun 23, 2017 10:57 am
If you already have wax on your bumpers then get some Quick Detailer sprayed on will easily remove the bugs and also can be used for the rest of the car if needed. I used to use Meguiars Last Touch, I now use Autosmart Tango but theres loads out there. Use a soft microfibre towel.
Baggie Austin
Post by Baggie Austin » Fri Jun 23, 2017 2:27 pm
Arvi wrote:If you already have wax on your bumpers then get some Quick Detailer sprayed on will easily remove the bugs and also can be used for the rest of the car if needed. I used to use Meguiars Last Touch, I now use Autosmart Tango but theres loads out there. Use a soft microfibre towel.
Agree a quick detailer should work, I use autoglym one and it's great for bits like that
Alpina Jim
Post by Alpina Jim » Fri Jun 23, 2017 11:26 pm
Thanks to all for your replies, some useful tips / info.
Jim
Alpina Jim
Post by Alpina Jim » Mon Jun 26, 2017 10:13 am
Bri-E wrote:Simoniz Bug Shifter is a brilliant also AutoExpress Products Award winner 2014. Spray on leave a bit, rinse off and dry no need to wash whole car.
I bought some Simoniz Bug Shifter from Halfords for £5. It did an excellent job and the front end of my B10 was bug free again in a few minutes. Spray on wait a bit and wipe off, really easy, and a lovely lemon smell :lol:. It also excelled at getting the bug splats off the windscreen so I will keep it in the boot of my daily driver for when I do a long journey.
Thanks again for the tip.
Jim
Toasey
Post by Toasey » Tue Jun 27, 2017 12:25 pm
For gentle dust removal I use a Polished Bliss lambswool duster. For bug removal I use Auto Finesse Citrus Power.
Both available from polishedbliss.co.uk
2000 E39 B10 3.3 Touring #10
1993 Eunos Roadster
1993 Saab Turbo 900 Ruby Edition
Gone but not forgotten: Ford Escort Mk 2 1600 Sport, Alfasud, Saab 900 GLS, Saab 900 Turbo (8v), MB W124 E320 Sportline Estate, Honda Accord 1.8S 6th Gen
