Henry
Post
by Henry » Tue Oct 17, 2023 8:03 pm
- IMG_0300.jpeg (2.7 MiB) Viewed 233 times
- IMG_0297.jpeg (2.93 MiB) Viewed 233 times
This is the result of poking my nose under sill cover just to see. Still I suppose that’s not to bad for 24 years. What else have I got to do on a cold wet day. Mean’s I’ll have to take the other one off to look or else I’ll end up thinking about it as I drive along.
B3 1999 (090)
E30 M3 1990
X5 4.6is
VW Mk4 R32
- ALPIN
Post
by JohnW » Thu Oct 19, 2023 5:41 pm
That looks like new section needing welding in there. I hope it turns out better than the photos suggest.
Henry
Post
by Henry » Fri Oct 20, 2023 6:30 pm
The jacking point once off is is solid, once the flacking paint is off behind the jacking point and wire brushed it is in remarkably good nick so has been rust treated and painted now looks excellent. I will however not use these jacking point again and instead use the round piece on the re enforcement piece under engine. The rear piece has been cut out and is waiting for a plate I’ve made to be welded in. I’m going to do inside the sills with Dynax S50.
B3 1999 (090)
E30 M3 1990
X5 4.6is
VW Mk4 R32
