E46 B3s rocket cover gasket replacement?
Post by hap » Wed May 08, 2019 5:52 am
Hi mine has a small oil leak towards front of the engine I have read a lot of owners have changed theirs as it’s a common issue
Does anyone have correct part number for said gasket I don’t think it’s alpina specific pls? How long would the job take at an indi and finally is there anything else that needs checking or doing at the same time ?
DogWagen
Re: E46 B3s rocket cover gasket replacement?
Post by DogWagen » Wed May 08, 2019 10:13 pm
Hi Hap - same issue on mine.
The gasket isn't listed in the Alpina Parts Catalogue so it should be standard BMW. Reading the Parts Catalogue second page, the base engine is the S52 used in the US E36 M3 - a quick check on realoem shows: https://www.realoem.com/bmw/enUS/showpa ... Id=11_6149
The part no listed at the link is 11120034108 - common to E39's too. Hopefully someone will confirm - perhaps Charles or Simon?
Can't help on job duration
Any help?
Mike
---pete---
Post by ---pete--- » Thu May 09, 2019 2:29 pm
Hi
I did mine a couple of years ago and went via BMW Sytner to ask the question. The part they said below was correct and fitted no issues within an hour by my mechanic.
Good afternoon
The part number for the rocker cover gasket is 11.12.0.034.108 and is a BMW part not ALPINA. You can order this with your local BMW dealer quoting this number. BMW UK has stock of these so standard lead time would be 48 hours Mon-Sat
Hope this helps
Peter Simmons
Parts Department
T: 0115 934 1492
F: 0115 934 1490
ALPINA GB
Lenton Lane
Nottingham
NG7 2AX
_____________________________________
2008 BMW Alpina B3 Biturbo Coupe no.137
2003 BMW Alpina B3s Coupe no.16
2014 BMW 525d M-Sport
2010 BMW 320d M-Sport
2000 BMW Alpina B3 3.3 Saloon no. 213
1995 BMW 328i Coupe
1989 Ford Escort XR3i lux
Post by hap » Thu May 09, 2019 3:34 pm
Great thank you guys for that
So an hours work approx
Post by simon13 » Sun May 12, 2019 8:46 pm
Its just a normal rocker gasket for a single vanos M50/M52 engine as fitted to any normal e36 e39 e38 or Z3
Part number given by the Dog man is correct.
Post by hap » Tue May 21, 2019 7:04 pm
Indi quoted me 150 all inclusive
